Is It Possible to Take Old Wav File, Find Beats, End Up with New PT Song?
Hello,
I have old .wav files of original music that I did in the 70's-80s. I can easily drag one of those .wav files into PT10. What I would like to do is, while following the tempo of the .wav file, is to record the song in PT10. After the PT10 version is complete, I would remove the imported .wav file. I have heard of Identify Beat and Beat Detective, however, is what I'm trying to accomplish possible in Pro Tools? Thank you for any advice, Tony |
Re: Is It Possible to Take Old Wav File, Find Beats, End Up with New PT Song?
If I understand correctly, you want to re-record these old songs track by track, using the original for a reference. So yes, all you really need to do is create your tempo map using beat detective, then once you have that set up, you can start re-recording.
- John If a MIDI event triggers a sample of a tree falling and there's no one there to hear it, does it make a sound? |
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
John_Toolbox,
Thanks for your reply. I'll start researching how to create a tempo map using Beat Detective |
I've done this exact thing with cover songs. There are great tutorials on Recordingrevolution and puremix to show you how to use Beat Detective. I ended up using the Identify beat function more than Beat detective to figure out tempos.
Good luck and have fun.
FBR recording - https://www.facebook.com/fromthebase...cordsrecording @FBRrecording - Instagram Rig MBP 15" High Sierra 10.13.3, i7 2.6Ghz, 8Gb DDR, 750Gb 7200rpm, PT 2019.5, Focusrite Saffire Pro 40, Octopre MkII, Glyph GPT50, Avalon 737sp, AMS Neve 1073's, API 512c, CAPI 312's, DW drums, Fender Guitars/Amps, AKG, Rode, Sennheiser, Neumann U87 & KM184's, Coles 4038, Equator D5 monitors |
Hello dr_daw,
Yes, using Beat Detective is going to be a little more difficult than I originally thought. The tempo of the song that I want to map is @124 bpm, however, after a few elementary Beat Detective tries the tempo appears to Beat Detective as @88 bpm. I will certainly take your advice and checkout Recordingrevolution and www.puremix.net. I assume you meant, http://therecordingrevolution.com. Lastly, I will also research Identify Beat as you stated. Thank you, Tony |
Hey Tony,
I found that as well with Beat detective and Identify beat, so unless the song was recorded to a click, it can be tough to nail down the exact tempo. I found the best thing was to select about an 8bar section, check that section, then move to the middle and do the same, so on and so forth. I would then take the average and set my tempo to that. If you're not planning on using anything from the original recording, I wouldn't get too caught up in making it match exactly. You're right, I meant 'therecordingrevolution'...I just searched on YouTube for finding the tempo of a song. That's where I got the info on 'Identify Beat'. Good luck, have fun
Take a look here.
http://www.youtube.com/watch?v=kXEkzbQKGgI
"In theory there is no difference between theory and practice. In practice there is." - Yogi Berra |
Thank you dr_daw for your additional input, and dave911 for the Youtube link.
I'm sure this will help a great deal. Tony |
Can someone help me find the sample that's used in my song? | protoolsuserman | General Discussion | 9 | 01-16-2014 02:30 AM |
Exact same song start, timecode and Bars/beats | 11miles | macOS | 1 | 08-08-2013 08:01 AM |
Could not save song cant find file specified | bmenchen | Windows | 3 | 06-07-2011 11:20 PM |
How does one find the RMS value of a song? | keithl | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 07-06-2004 08:06 PM |
trying to find a song by Exit 57??? | tractorman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 04-03-2002 03:05 PM |
