Avid Pro Audio CommunityHow to Join & Post Community Terms of Use Help Us Help YouKnowledge Base Search Community Search Additional Resources |
Ive been meaning to post this for ages but I always forget once Ive finished in the studio.
When I have the smart tool selected and move it around a track on the edit screen you some times have to get it in the exact right place for it to change to the tool You want to use. Is there a way to press a keyboard key that you hold to make it become the trim tool, or the grabber hand etc. I know you can press the F keys at the top to change what the mouse does but some times Im changing around a lot I just wondered if you could hold a key to make things quicker and easier?? Sent from my iPhone using Tapatalk
Raoul Crane
www.blaze-studios.co.uk PT 10.3.10 HD Accel 6, Mac Pro 3.1 Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis |
The smart tool changes depending on what area of the clip the tool is mousing over, at either end of a clip it turns to a Trim tool(s) pressing Option on a Mac flips these tools. in the lower half the Grabber tool, the upper half the Selection tool, pressing Control on a Mac turn to the Audition tool. Top left and right corners respective Fade tools, bottom right corner Crossfade tool.
It’s quite a dynamic tool once you get used to it, and I find I use it quite a lot.
Rob MBP 15 2018 macOS High Sierra 10.13.6 Touch Bar and ID 2.2GHz 6 core 8 gen Intel Core i7 processor (TBs to 4.1GHz) 32 Gb of 2400MHz DDR4, 1T SSD, Magic Mouse and Keyboard Pro Tools 2018.12, Cubase AI 9.5, Yamaha TF5, UR44, BEHA4700 ........and a bowl of M&M's |
Every tool has its shortcut. Just go through cmd 1-6 (number row NOT number pad). Some numbers let you cycle through different modes of the same tool when you repeat the command.
F5-F10 does the same.
iMac Pro - OSX 10.12.6 --- - Pro Tools HDN 2018.10 - Avid HD Omni + HD I/O 8x8x8 - C|24 |
fade tool disappeared from smart tool | RobinWinjil | Pro Tools 10 | 1 | 06-27-2012 12:27 AM |
Weird Smart Tool/Selector Tool issue? | Marsdy | Pro Tools TDM Systems (Mac) | 11 | 01-15-2012 08:22 AM |
Get Grabber tool (Object) as part of smart tool? | buckaroo | Pro Tools TDM Systems (Mac) | 8 | 07-13-2010 05:21 AM |
Smart Tool / Pencil Tool in Midi Editor | AndyJCP | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 04-26-2009 09:08 PM |
Question about the Smart Tool | tonwurm | Pro Tools TDM Systems (Mac) | 2 | 02-19-2009 12:16 PM |
