Old 02-08-2013, 02:51 AM
Klopfgeist Klopfgeist is offline
Default DSP EDIT/ASSIGN section - No menus only lights
I was wondering if anyone has come across this :
PC DSP EDIT/ASSIGN section shows only light squares instead of the usual menu read-outs.
I'm not sure if this is a hardware problem or if it has to do with software compatibility.
Apart from this faders, automation etc work as expected
We're using a PT 10 HD - (192 and Sync IO) - Mac Pro running 10.6.8
I'd really appreciate any help as I'm a bit stuck
Stephen Taylor
Here's a photo :
Old 02-09-2013, 11:22 AM
blackmacdaddy blackmacdaddy is offline
Default Re: DSP EDIT/ASSIGN section - No menus only lights
My ProControl is working fine on 10.6.8 with 10.2 HD.
Have you gone through all of the utility menus?
You may be able to reload the firmware?
I think if you revert it by holding a certain set of keys & then fire up Pro Tools it will try to update the firmware (as long as it is newer.)
Good luck.
PS: I have heard of people having power supply issues causing weird things to happen. The quick fix is to disconnect the power connector to the monitor section (as most folks, myself included don't use it. I use a Presonus Monitor Station myself. The Dust Brothers were recently selling their ProControl & had done just this to it)
It's only R'n'R but I like it.
Old 02-15-2013, 03:51 AM
Thanks blackmacdaddy for the reply,
I've done the firmware update.
I'll look into disconnecting the power connector - we do use the cue send & TB though (we're an audio school so I can't really go too far from standard procedures regarding signal flow)
If I find the solution I'll post
Old 02-21-2013, 02:42 PM
Delta Music Belgium's Avatar
Delta Music Belgium Delta Music Belgium is offline
It has nothing to do with any firmware updates, the Pro Tools software updates the firmware when it is needed automatically. It think it is hardware related. I would open the ProControl Main unit, disconnect all the connectors you can find, maybe clean them (and removing all dust inside the machine) and then reconnect all the connectors. I revived quite a few ProControls just by executing this procedure. ProControls are getting old an corrosion starts to act up from time to time... Maybe this can help to revive your ProControl too...
Marc Schellekens
Delta Music Belgium - Dolby Atmos Music Studio
https://www.deltamusic.be
Mac Pro 2019 - 3.2GHz 16-core - 96GB RAM - macOS 14.4.1 - PT HDX3 - Pro Tools Ultimate 2024.3.1 - Avid HD I/O 16x16 (x2) - Avid HD I/O 16x16 Digital - Digidesign 192 I/O - Digidesign 192D I/O (x3) - Avid SYNC HD - Apogee Big Ben - Apogee Rosetta 200 - Avid S3 - Slate RAVEN MTi2 (x2) - iConnectivity mioXL (x4) - Genelec ‘The Ones’ 9.1.6 Dolby Atmos Music monitoring (AES/EBU) with 8341A (x5) + 8331A (x10) + 7360A (x2) + 9301B - Almost all available AAX-DSP plug-ins
blue lights or green lights when loading up... zippitydoodah 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 06-15-2007 01:58 AM
DSP/Edit Assign bug Pete Gates ProControl, Control|24, Command|8 1 12-08-2006 02:13 AM
ProControl DSP/EDIT ASSIGN section problems Pete Gates ProControl, Control|24, Command|8 4 05-20-2006 01:48 AM
Edit highlight section it says no audio selected rcourell1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 01-06-2005 05:31 AM
"Timeline" and "Session" lights in edit window Paul Cavins 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 02-15-2004 08:10 PM
