Please help confirm a midi/delay comp bug
http://db.tt/PvM69fGY
Please open this small PT session with acoustic snare hit and midi duplicate of it (created with Massey DRT) and tell me if you get a big FLAM between the two tracks. And if so, does the issue go away when you disable a empty track named INACTIVATE ME? Only Avid plugins used, Boom and Maxim. Thanks! |
Re: Please help confirm a midi/delay comp bug
yep. tried this in PT10.3.6 and I get the flam. Deactivate the track with Maxim and they play in time.
Then I tried it with PT11 and it seems to be working fine there, so that's good news.
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
I moved this over to general PT10 thread since I have the issue on my laptop mac too.
Thanks Benoni, looks bad. Please guys, check this and repot back. |
Also confirmed that it is not working right on my system either. Any suspicion on what is happening so I know how to avoid this?
Oh, this is happening on 10.3.5 Mac 10.7.5
recording.guru : FREE Pro Tools Tips and 19 Video Basic Training Course Pro Tools HDX 2023.9 Mac Pro 7,1 3.2 GHz 16-Core Xeon W 160 GB RAM macOS 11.7.4 Noisebox Studios -Utah Recording Studio |
I also just discovered something. I moved the MIDI over to the instrument track and then it compensates just fine. So it must be a bug with compensation with MIDI tracks.
EDIT: Even if you create a new Instrument Track and send the MIDI Outputs to Boom it works just fine. So perhaps the bug can be avoided by using Instrument tracks in place of MIDI tracks. Annoying, but works.
Not sure if this adds to the discussion - I get similar issues rendering MIDI tracks to audio when I have an instance of Ozone 5 on another completely unrelated track. I get delay issues similar to this. Turn off Ozone & the problem disappears. I've not really investigated why this happens, I guess something to do with delay compensation in the background.
I'm trying to go back to PT 10.2 on my PC to see if that fixes the issue. Can't go to 11 since I'm using Accel. |
Please confirm/ deny: Sidechain inputs are not delay compensated in PT10? | mr xy | Pro Tools 10 | 17 | 02-04-2015 12:19 PM |
midi track record turns off all other midi/instrument tracks delay comp | holyspicoli | Virtual Instruments | 4 | 07-18-2013 06:14 AM |
Delay Comp problems again, Delay comp is RED but way below limits. | soundeq | Pro Tools TDM Systems (Mac) | 13 | 11-29-2011 12:01 PM |
delay comp = red on aux | strewnshank | Pro Tools TDM Systems (Mac) | 11 | 07-20-2010 02:42 AM |
Midi learn in PT 8 and bus delay comp | peter99 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 08-18-2009 12:43 AM |
