Old 05-30-2016, 09:39 AM
SomeOtherGuy SomeOtherGuy is offline
Default Scale MIDI CC data
Is there no way to scale MIDI CC data such as Mod Wheel? There are scale options for velocity and duration, but none for other data types. Every major DAW can scale -- hope I'm missing something.
This, along with Pro Tools' inability to remap MIDI CC data, are two things that'd be very easy to add, I would imagine, no?
Pro Tools Ultimate 2019.6, Avid MTRX, MOM, Mac Pro 3.5 Ghz 6-Core (2014) 64 GB RAM, Mac OS Mojave, Samsung T5 SSDs
Old 06-03-2016, 10:14 AM
Default Re: Scale MIDI CC data
bump, thx.
Old 06-03-2016, 10:36 AM
studioj11 studioj11 is offline
There is not a way to scale by percentage in PT that I know of. at times I have moved MIDI into other DAWS like DP or Logic to perform certain MIDI tasks. You can of course simply "trim" the cc data like you would other automation.
To convert cc data between different cc's, copy (or cut) the source cc data and then select the range on the lane for the new cc destination, and then hit control command V. This will "paste to current automation type" to the new cc lane what you copied from the other cc.
Midi change duration, scale by %. Ivan S macOS 3 07-18-2013 07:51 PM
Idea Scale - please vote - Midi Feature Request YYR123 Pro Tools 11 8 04-29-2013 03:10 AM
Midi change duration, scale by xy%. Ivan S macOS 3 04-10-2011 09:50 PM
Is there to create a custom scale I can play back using MIDI? GenerationM 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 01-19-2009 06:42 PM
PT 6.9 - MIDI - scale time? jeremyroberts Pro Tools TDM Systems (Mac) 3 05-18-2005 07:36 PM
