Old 07-21-2015, 02:36 PM
DJ Hellfire DJ Hellfire is offline
Default Crappy elastic audio sound quality?
Anyone else getting choppy/noisey audio quality using elastic audio? In my specific example, I simply stretched an 8 bar piece of audio from 91 bpm to 90 bpm. In doing so, the audio became glitchy in certain parts and making a ringing noise in other spots. The ringing noise went away after reloading the session, but the glitchiness is still there. And I've done WAY more drastic tempo changes in the past on ENITRE sessions without any noticeable audio glitching. Anyone else getting this?
Here's an example of a song I used elastic audio on back in like PT8 or 9. I shrunk ALL of these vocals by over 5 BPM because this song was recorded to a different beat, and I made this beat around the song at a faster tempo. You can't hear any glitching in the vocals.
http://surgandhellfire.bandcamp.com/track/holy-water-2
www.HellfireBeats.com
Akai MPC 2000XL, Akai MPC X, Mackie 1202VLZ Pro, Akai Advance 61, Focal Alpha 80, UAD 2 Apollo Quad, UAD 2 Satellite Quad, UAD 2 Octo PCIe, Neve R6 "Lunch Box", Neve Portico 511, Neve Portico 551, Neumann TLM49
Pro Tools 2018.10
Mac Pro 4,1 (5,1 upgrade), Early-2009, 3.46GHz Nehalem 12-Core, 32GB RAM - OS 10.12.6
13" MacBook Pro, Late-2011, 2.4GHz Dual Core i5, 16GB RAM - OS 10.12.6
27" iMac, Late-2012, 3.4GHz i7, 24GB RAM - OS 10.12.6
Old 07-21-2015, 03:07 PM
makinghits makinghits is offline
Default Re: Crappy elastic audio sound quality?
Yep. Posted about this before. The problem goes away when I reload the session. Far from ideal.
PT 11.3.1 /Win7
Old 07-21-2015, 03:43 PM
AlexLakis AlexLakis is offline
Yes, I can confirm this; I started a thread about it but it went quietly away...
I can get the glitches to stop by committing EA on all tracks. Just one track in "live" EA mode produces glitches on playback and bounce.
Never experienced glitches like these on Pro Tools 10 and below. Absolutely nothing has changed on my system from that time except 10->12.
Old 07-21-2015, 04:00 PM
Wall2Wall Wall2Wall is offline
keep it simple. your last step should always be X-Form.
Old 07-21-2015, 04:07 PM
Indeed^^^. Once you make your moves, switch to X-form and let it render. I actually do all my EA edits in X-form. It takes longer, but sounds way better. The trick is to chop up the audio file into sections that fit on the screen. As EA renders, it goes faster if its working a smaller clip.
Old 07-21-2015, 04:30 PM
(Breaks out the ol' soapbox)
X-Form has been rubbish since PT 8. I keep an old PC around with Pro Tools 7.4 for the sole purpose of using X-Form when absolutely needed. Phasey garbage since it was revamped in PT8 (using the same exact workflow). I can get away with stuff in 7.4 that I can't get close to with X-Form on 8+.
I remember speaking to the programmer who coded the new stuff, but this was years ago and I fear he might not be with Avid anymore...
(gets off the ol' soapbox)
Regardless, these glitches in "live" EA on 12 are different from the standard EA artefacts, and should NOT be happening.
Old 07-22-2015, 03:49 AM
clausiii's Avatar
clausiii clausiii is offline
EA algos were coded by iZotope afasik.
My ears! My ears!
clausiii
MacBook Pro i7 Quad 2.6GHz 16GB RAM
ProTools 2019.5
Digidesign Command|8
macOS Mojave
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
Roli Seaboard Block
tons of stomp boxes
tube amps
guitars
noise
Old 07-22-2015, 04:46 AM
midnightrambler midnightrambler is offline
As always with these things it's not a case of absolutes. Sometimes X-From sounds better, but sometimes it really badly smudges transients, especially on things like bass. So, in my opinion you have to try each algorithm out on a case-by-case basis.
Old 07-22-2015, 04:48 AM
keep it simple
Nonsense. "Make it right".
Old 07-22-2015, 07:24 AM
dankin dankin is offline
It's frustrating to me that EA has never been updated to sound better, or use 3rd party algorithms. It works ok for some things that are going to be buried in the mix, but for anything exposed I always manually cut and time stretch with sound shifter or pitch N time. It takes longer, but the sound quality is much better.
Elastic Audio sonic quality BDWillis Pro Tools TDM Systems (Mac) 58 08-20-2009 03:12 PM
ELASTIC AUDIO - A GOOD QUALITY RESULTS ? ON BASS TRACKS ? djani 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-25-2007 06:16 PM
Great Song/Crappy MP3 Quality - PLEASE HELP!!! epu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 08-10-2007 10:38 PM
Why iS Sound Replacer so Crappy? Chompers 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 27 05-25-2002 02:37 AM
Do I lose any sound quality using Toast DAE to extract audio from audio disk BboY 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-15-2002 07:16 PM
