Old 12-29-2009, 12:43 PM
lawdaproducer lawdaproducer is offline
Default Aux track routing to audio track not working
I am trying to print audio from Abelton Live which I have routed to PT via Auxillary tracks. As outlined in video demonstation on Youtube, I've done the following
Set up rewire tracks:
1. created aux tracks
2. assigned Ableton Live plugin
Set up Ableton live:
1. launched Ableton Live
2. choose rewire as output
3. assigned each track in Live to a bus channel
Assigned Abelton Live signal to individual aux tracks in Pro Tools:
1. assigned the Live track to individual aux tracks in Pro Tools by selecting the desired rewire bus channel in the ableton live rewire plug-in window.
In Pro Tools, Assigned the Aux track output to a bus and the Audio Track input to the assigned aux bus output.
ex. Aux Track (output = bus 1/2) Audio Track (input = bus 1/2)
Press record enable on audio track.
result - No signal routed from the aux track to the audio track.
note: Signal is coming through via rewire.
Has anyone experienced this and have a solution on how to fix?
Thanks,
Law Daproducer
Old 12-29-2009, 12:56 PM
Default Re: Aux track routing to audio track not working
NEVERMIND.........
I just discovered that PT will not allow you to monitor the audio input during playback. I actually had to record the signal. Hmm that doesn't make any sense!!!! Is there some type of setting that I need to adjust that will allow me to actually monitor before I record?
Hybrid midi track to audio track via bus send is not working joshfrog94 Tips & Tricks 1 11-02-2010 07:46 PM
MIDI track routing to Aux track quick question Mason00 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 09-28-2006 08:30 AM
Routing Reason to a PT audio track Roy Howell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 02-14-2004 06:11 PM
routing audio to a track soca007 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 07-14-2002 08:19 AM
