Old 07-18-2009, 01:36 AM
RhodesB3 RhodesB3 is offline
Default MIDI instrument track strangeness
Not sure how to search for this.. When using an instrument track, a few things are acting strange.
1. Even when the instrument track in not in record, my keyboard is still triggering sounds. If I create other instrument tracks, and put them in record, they sound, but when i take them out of record, the first track I created is being triggered.
2. When using instrument tracks, they aren't always getting midi. Even when I've duplicated another working instrument track. Very strange.
I am assuming that its best to record directly onto an instrument track. If I set up another midi track and set the instrument track as the output, it works. I'd love to just be able to rely on using the instrument tracks without having to setup another midi track.
I am using a pc88 with a midi timepiece AV.
Cheers!
Old 07-18-2009, 02:26 AM
Stig Eliassen's Avatar
Default Re: MIDI instrument track strangeness
This is by design. It's sufficient for an instrument track to be selected/highlighted to receive MIDI.
Old 07-18-2009, 02:44 AM
tonwurm's Avatar
tonwurm tonwurm is offline
Originally Posted by RhodesB3 View Post
1. Even when the instrument track in not in record, my keyboard is still triggering sounds. If I create other instrument tracks, and put them in record, they sound, but when i take them out of record, the first track I created is being triggered...
you can change this behaviour in the "Preferences/Midi" settings
Mac Pro 2010 - PT10 HD3, PT12 HD, Logic X, DP 7, VEPro, OSX 10.9.5 / 10.12.6
MacBook Pro - Logic X, Mainstage
Old 07-19-2009, 01:43 AM
suicune suicune is offline
...and with regards to point 2 you probably just need to check your instrument IO settings. Go to view and in either the mix or edit window views enable the 'instruments' option. This page displays the IO MIDI ports. Check that it is receiving from the correct MIDI port, and that the output refers to the correct instrument port and channel. It is though this page that you can access different channels on multi-instruments like structure. An incorrect setting here could be what's killing your MIDI.
I've often found that duplicating an existing instrument and then changing the insert can cause this to default to the wrong port. It may be quicker for you to create new instrument tracks instead of duplicating existing ones, as then it sets the ports correctly by itself.
M2 Studios
Wolverhampton, UK
http://www.madhat.co.uk
copy instrument track to midi track trev1238 Pro Tools 9 5 02-04-2012 01:16 AM
Difference between Midi Track & Instrument Track better? paul Neathery 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 07-16-2007 04:03 PM
Mapping MIDI Track To Instrument Track Delta Dreams 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-08-2007 11:26 AM
midi outputs? aux track or instrument track? pikapikapi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 12-19-2006 02:28 AM
using instrument track vs. midi+auxilary track digimike 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-02-2006 09:21 AM
