Old 04-01-2004, 07:53 PM
Samhein Samhein is offline
Default Digidesign 7 Slot Expansion Chassis work with HD?
Went through the Digidesign's "Confusion"ability documents, but couldn't get the info.
1. Do all Digidesign 7 SLot Expansion Chassis models, regardless of when they were manufactured, work with HD system on PowerMac G5? Because it seems only the 13- Slot Digi Chassis have incompatible serial number models.
2. How many HD cards can be used in the 7-slot chassis when used with a G5?
Thankssssssss.
Old 04-02-2004, 07:48 PM
Bump..
Old 04-03-2004, 06:43 PM
DigiTechSupt's Avatar
Default Re: Digidesign 7 Slot Expansion Chassis work with
The information you need is here:
http://www.digidesign.com/compato/osx/hd/expand.cfm
The maximum number of HD cards in a system is seven. The Digidesign branded 7 slot should be fine. The Digidesign 13 slot needs to have a serial number higher than NB0600100C.
Thanks,
Digidesign Tech Support
Avid Audio Tech Support
Support FAQ
Digidesign 13 Slot 32-bit Expansion chassis with pt 7.4? arche3 Pro Tools TDM Systems (Mac) 0 07-22-2009 12:15 PM
Digidesign expansion HD 6 slot chassis experiences! crizdee Pro Tools TDM Systems (Mac) 12 01-25-2009 12:20 PM
Cable for Digidesign 7 slot pci expansion chassis? tenUK Digidesign Hardware & Software 3 09-12-2007 08:04 AM
7 slot Digidesign SBS expansion chassis MDog Pro Tools TDM Systems (Win) 0 12-23-2004 11:36 AM
