Steven Slate Drums 4 question
I just bought this on a whim. I'm used to Addictive Drums and Strike, which both seem to have more mixing capability than SSD4.
Is the modus operandi for this plug-in just to use multi-out, and just mix as though it was audio?
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB |
Idk I was planning on buying that for the samples alone,
What did you think about them?
The samples might be in a proprietary format, I'll let you know when I get it installed.
Re: Steven Slate Drums 4 question
The SSD4 samples are indeed proprietary format (.ssd / .ssi). Most of them are very good.
SSD4 is meant to be used in a "multi-out" setup. It has no plug-ins inside its mixer, though it has simple attack, sustain and release for each drum instrument (which I find useless in its current implementation). It has extensive controls for levels, pan, bleed levels, bleed routing and creation of busses, though. I've used Superior with its built-in plug-ins, and I clearly prefer to just forget about those plug-ins (inferior quality) and route out the instruments and mix in the DAW. Using multi-out with SSD4 can give very nice results, in my opinion. Maybe I can do a quick video to showcase a raw kit and a mixed one. |
SSD 4....Great drum library. I'm a drummer myself, and own all of the major libraries. Triggering from a V-Drum kit and the way the Slate samples sit in the mix, I prefer them over anything else for rock, pop or country.
Lynx Hilo Thunderbolt 2013 Retina Macbook Pro 2.7 16 GB of RAM PTHD 11.3.1 OSX 10.10.1 |
I should add that I typically print all the channels to audio and then do all my processing in the DAW as if it were a live drum kit multitrack.
Steven Slate Drums 4 Question | anothercolour | Virtual Instruments | 2 | 08-16-2014 05:19 AM |
Slate Digital and Steven Slate Drums AAX | DHL | AAX Plug-ins | 6 | 04-22-2013 12:50 PM |
Steven slate drums help with Hi Hat | Raoul23 | The Drum Room | 4 | 03-13-2013 07:21 PM |
PT8 LE and Steven Slate Drums | outlaw69uk | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 09-30-2010 08:00 AM |
Steven Slate Drums....$20 | pguy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 02-27-2010 12:40 PM |
