Old 11-15-2010, 09:58 AM
yeluhz_strongs yeluhz_strongs is offline
Default PT 9: Won't Launch + Pace Error
I decided to crossgrade to PT 9 from 8.04 cs2 yesterday and it installed fine. My PC is Win 7 Prof. 32-bit, i7 930 2.8 Ghz, 6 gigs ram, ATI Radeon HD 4770.
However, PT won't open, I double-click, I see the little hour glass then nothing happens. I right-clicked and used 'Run as administrator' even though I am logged in as Admin, and nothing.
I installed the 003 firewire drivers as well.
I figured it would be the PACE/iLok Driver, so I installed the newest version and now get an error during installation.
Error 1920.ServicePACE License Services (PaceLicenseDServices) failed to start. Verify that you have sufficient privileges to start system services.
In my Control Panel I see that iLok Client Helper 5.9.1 and Interlok driver setup x32 5.9.1 are installed.
Helpful tips?
Thanks
Old 11-15-2010, 10:03 AM
lennieh lennieh is offline
Default Re: PT 9: Won't Launch + Pace Error
Have you done all the Win7 optimisations??
If not then turning off DEP and UAC and then starting again will likely help you.
Old 11-15-2010, 10:38 AM
I followed the recommended optimizations.
For the DEP, I chose which files to exclude before, but now I just entered the cmd to turn it completely off and I am re-installing PT 9 at the moment.
Will post back in a few mintues.
Old 11-15-2010, 10:52 AM
Nothing, again!
No splash screen--not even an error message!
I opened my Task Manager to view what Processes are running;
I see Pro Tools.exe, using ~26,000 K of memory usage, but then it disappears after 30 seconds!
Old 11-15-2010, 12:21 PM
Spent 40 minutes on hold to wait for a Tech Agent and decided to hang up.
~_~
I submitted my case now, Case : 01403832
Old 11-15-2010, 03:52 PM
bootybandit bootybandit is offline
Red face Re: PT 9: Won't Launch + Pace Error
Atleast I'm not alone, I've been trying various ways for 5 days now, and have finally arrive at the point where there's NO more errors (PT9 nor iLok)........but it won't launch. It turns for 30 sec., loads as a task file then, nothing; it simply quits.
All drivers are updated (PT9 MBox2 mini, Ilok client & driver, w7, etc.)
There's 2 PT9 defiant "ntdll.dll" errors listed in my windows events log each time I try to run it:
C:\Program Files (x86)\Digidesign\Pro Tools\ProTools.exe, ntdll.dll, version : 6.1.7600.16559,
also listed in the same file:
C:\Windows\SysWOW64\ntdll.dll
So...........the problems are here! Check your files, maybe you have the same.
I finally rolledback to PT8 for now but it's a shame when I've paid for PT9.
There must be a quick fix happening..........soon!
Ilok not updated errors:
iLok does NOT currently have drivers for PT9. They are included in the PT9 driver update
If you're having PT9 driver errors really pay attention to the instruction 'cause they can be quite confussing; it's quite a jiggsaw:
- PT9 Mbox (MBox 3)
- PT9 MBox2 Family
Make the right choice.....
Healing the world through music.................
Sony Vaio Laptop|2 Core P8700 2.53 Ghz 8 Gb Ram|Win8 x64
PT 9.0.6|Cubase 7|Samplitude Pro X|Reason 5|Spectrasonics|Komplete
RME BabyFace|AxiomPro49|Akai LPD8
Old 11-15-2010, 04:45 PM
Man, pay that much money to not even launch!
I checked my Event Log and it read:
Faulting application name: ProTools.exe, version: 9.0.0.121, time stamp: 0x4cc25876
Faulting module name: ntdll.dll, version: 6.1.7600.16559, time stamp: 0x4ba9b21e
the ntdll.dll file is located in,
C:\Windows\SYSTEM32\ntdll.dll
Tried the tech support, AGAIN, and waited 20 mins with no luck.
Old 11-15-2010, 05:38 PM
Don't like to say, I told cha so, but.............I told cha!
And no one from Avid nor the genies of the forum are acknowledging it, hmmm.
Now ain't that a croc-o-crap !
Old 11-15-2010, 06:27 PM
And what good is one complimentary phone support if I can't get through?
Old 11-15-2010, 07:43 PM
Over a hundred views and no tips or solutions from anyone?
No other similar cases?
[IMG] code is Off
The installer was unable to launch the PACE system files installer - Help please buzz302 Pro Tools M-Powered (Win) 3 02-14-2012 10:05 AM
TPkd error & pace error trying to install that too rost 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 05-04-2008 06:13 PM
PACE Extension Warnings on 7.4 Leopard Launch Mount Royal Pro Tools TDM Systems (Mac) 2 02-25-2008 08:03 AM
Unable to launch PACE System Files installer Ab7b9 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-17-2003 09:34 PM
Pace error PTLE6.1.1 gonzolagonda 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-30-2003 07:12 AM
