  #21
Old 07-16-2013, 01:03 AM
MJarzabek MJarzabek is offline
Default Re: Logic Rewired through PT?!
I know this thread is a bit old, but here's an easy way to route mainstage into pro tools and keep audio in the computer.
Set up a MIDI IAC Bus, create an aggragrate io, download soundflowerbed, include soundflowerbed in your new aggragate io.
Launch pro tools and make your new aggragate device the audio output. create an audio and midi track.
launch mainstage. set the outputs to 3-4 on the channel strip. (you can only bus one stereo instrument over at a time).
in pro tools, send the midi track output to the IAC Bus Midi Port. Make sure the MIDI input is NOT set to all. Make sure it's set to your MIDI controller specific.
On the audio track, set the input to 3-4.
You should be set to go.
Hope this helps guys.
Still working.
Hosting 32-bit VIs in 64-bit Reaper Rewired to PT Top Jimmy Virtual Instruments 9 12-19-2013 11:48 AM
C8 not co-operating with rewired Live clutch ProControl, Control|24, Command|8 0 01-22-2006 03:00 AM
C|8 and rewired apps silverlode ProControl, Control|24, Command|8 4 12-27-2004 08:23 AM
can garageband be rewired LL Lush 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 05-31-2004 09:05 AM
reason rewired cant see LL Lush 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-19-2004 11:01 PM
