Re: Machine control
Can you please send yourself over fiber to go spam some other forum? Darryl Ramm |
Re: Machine control
Keep thinking - "this is the year of tapeless" but unfortunately I'm still having to deal with Machine Control.
It's an embarrassment, I think people that have grown up with only Pro Tools just accept it and assume that 9 pin control generically just isn't very good. I'm another ex-Fairlight user and Pro Tools machine control is laughable compared to that. There are very good reasons that I, and most of the other ex-Fairlighters, moved to Pro Tools but machine control isn't one of them. Why can we still not with one button push drop in on the machine and Pro Tools, yes I know some of the rubbish clunky ways round that. Pete |
Re: Machine control
Machine control in pro tools is bad but not that bad. It's very workable, just extremely clunky with a few bugs thrown in.
Brandon Howlett Vibe Audio Post, Inc. Re-recording Mixer Custom Build CPU, HDX 1, Omni, 192 I/O Digital S6 M10 24 fader Satellite Mac Pro, HDNative, 192 I/0 Black Magic HD Extreme |
Re: Machine control
Sounds pretty bad to me! 😊
Re: Machine control
You'd make a good used car salesman...
#16
Re: Machine control
I never used a Fairlight. I work with some people who used to use a Fairlight. One of them worked on a DREAM. The tech who had to support that system called it the NIGHTMARE.
The people who used the Fairlight said that its machine control was superior to Pro Tools. I have used the MicroLynx. The MicroLynx was easier to use than Pro Tools' machine control. Someone here wrote that you get used to it. It's true. I became the king of machine control and even distributed some machine profiles back in the days of yore. Some Avid techs even asked me for my profiles. Machine control did get better between v7.4 and v9. I am not sure which company bears more of the blame for the debacle that is the SRW-5500 when working with Pro Tools. All I know is I had some bad experiences with that deck and machine control. It wasn't until I went to NAB 2009 and cornered a Sony engineer that he showed me the super-secret deck settings I needed in order to layoff in sync without a problem. By then it was too late with regards to my bad experiences. At least I did not have to relive them.
#17
Re: Machine control
That's a problem with any of these HD decks. You cannot accurately scrub an SRW-5500 or an AJ-HD3700B (D-5). You can scrub it back and forth over a time code point a few times and see if you get what you want at a particular time code often enough. Those decks cannot be scrubbed in the same manner as a DVW-A500.
#18
Re: Machine control
There is absolutely nothing wrong with machine control. I have been doing my own laybacks twice a week for the last 5 years on a SRW 5800. There are menu settings you need to be aware of to do a proper in sync layback. (Do a search here and on Gearslutz) I print stems and layback through stem track input with no issues. You CAN NOT view the tape while listening to Protools, while the deck is track armed. You must listen through the deck's output due to a 4 frame time code pre-read. We are finally delivering digital files! But thats a nightmare for the online editor now!!
IMDB |
#19
Re: Machine control
Pete |
#20
Re: Machine control
You categorically can't say that Pro Tools is as easy as that. I do dozens of laybacks myself all the time (DigiBeta (still occasionally!)/HDCAM/HDCAMSR) on Pro Tools and I can do it fine and it works and I don't have problems but it's unnecessarily fiddly and I have to check a lot more things than I used to have to, yes it becomes part of your routine but it's a bore! As to your first point, in 32 years I've rarely had the say as to when I'm doing the layback, perhaps I'm not assertive enough! As to your last point, yes! Recently had something fail QC due to the files being sent out as dual mono, I had supplied stereo to the online. Pete |
Machine control | lode | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 09-21-2004 08:59 AM |
Pro control & Machine control software | samcu | ProControl, Control|24, Command|8 | 0 | 03-08-2004 04:24 AM |
Machine Control and 6.0 | Gio Mix | Pro Tools TDM Systems (Mac) | 1 | 03-12-2003 08:30 AM |
MIDI Machine Control out of control | zenbarai | Post - Surround - Video | 3 | 04-19-2002 07:08 AM |
PT5.1 and machine control | kuen | Pro Tools TDM Systems (Mac) | 15 | 05-09-2001 08:01 AM |
