  #21
Old 12-12-2013, 06:29 AM
feliponk's Avatar
feliponk feliponk is offline
Default Re: Proper Recording Levels
Keep it in the yellow range and some orange peaks, that's it.
Felipe Gonzalez A.
Avid ACSR Elite
Dante Certified
http://felipousismix.wix.com/felipousismix
Open Core Mac Pro OSX Ventura | ProTools HD 2023.x | Merging HAPI ADA8 | UAD Quad PCIe | Kali IN-8 | Presonus Temblor 10 | Softube, SSL, Universal Audio, Slate Digital, McDSP, Fabfilter, Plugin Alliance among other plugins
  #22
Old 12-12-2013, 07:09 AM
bryced87 bryced87 is offline
But what is the difference between the numbers on the right and left. I've heard never to have it in the yellow.
Macbook Pro
Mac OS 10.10.3
Mbox 2,
Pro Tools 11
  #23
Old 12-12-2013, 07:17 AM
feliponk's Avatar
Who told you that?, have you read the manual to kow what this numbers mean?
Felipe Gonzalez A.
Avid ACSR Elite
Dante Certified
  #24
Old 12-12-2013, 07:19 AM
no but the tutorials online say if you have it in the yellow you have less headroom for mixing
Macbook Pro
Mac OS 10.10.3
Mbox 2,
Pro Tools 11
  #25
Old 12-12-2013, 07:21 AM
feliponk's Avatar
That's b*llsh*t.
You need to know how to do your work.
Have you read the manual?
Felipe Gonzalez A.
Avid ACSR Elite
Dante Certified
  #26
Old 12-12-2013, 07:28 AM
no i was taught in college not to believe the manual. I found this from http://www.harmonycentral.com/t5/Rec.../ba-p/34646453
"The track labeled Audio 1 is at -15dB, which is the equivalent of "0 VU" in Pro Tools. This is about where your average signal levels should be when recording."
-15 is green
Macbook Pro
Mac OS 10.10.3
Mbox 2,
Pro Tools 11
  #27
Old 12-12-2013, 07:33 AM
feliponk's Avatar
From Wikipedia...
dBFS is not to be used for analog levels, according to AES-6id-2006. There is no single standard for converting between digital and analog levels, mostly due to the differing capabilities of different equipment. The amount of oversampling also affects the conversion with values that are too low having significant error. The conversion level is chosen as the best compromise for the typical headroom and signal-to-noise levels of the equipment in question. Examples:[15][16][17]
  • EBU R68 is used in most European countries, specifying +18 dBu at 0 dBFS
  • In Europe, the EBU recommend that -18 dBFS equates to the Alignment Level
  • European & UK calibration for Post & Film is −18 dBFS = 0 VU
  • UK broadcasters, Alignment Level is taken as 0 dBu (PPM4 or -4VU)
  • US installations use +24 dBu for 0 dBFS
  • American and Australian Post: −20 dBFS = 0 VU = +4 dBu
  • The American SMPTE standard defines -20 dBFS as the Alignment Level
  • In Japan, France and some other countries, converters may be calibrated for +22 dBu at 0 dBFS.
  • BBC spec: −18 dBFS = PPM "4" = 0 dBu
  • German ARD & studio PPM +6 dBu = −10 (−9) dBFS. +16 (+15)dBu = 0 dBFS. No VU.
  • Belgium VRT: 0dB (VRT Ref.) = +6dBu ; -9dBFS = 0dB (VRT Ref.) ; 0dBFS = +15dBu.
Felipe Gonzalez A.
Avid ACSR Elite
Dante Certified
  #28
Old 12-12-2013, 07:45 AM
Now I'm really confused because a friend of mine from Berklee Music says that dBFS is what you always go by. He says set it so that peak is displayed on the fader and never go over yellow. I don't even know what dBFS is.
Macbook Pro
Mac OS 10.10.3
Mbox 2,
Pro Tools 11
  #29
Old 12-12-2013, 07:51 AM
feliponk's Avatar
Start reading then, and with this, I'm not insulting you at all.
All of us are learning everyday, but you need to put from your side. After 23 years as a professional, there's a lof of things I need to learn, that's why I keep reading and researching.
Look here for the dBFS but bear in mind you need to understand sound and signals first.
http://en.wikipedia.org/wiki/DBFS
Felipe Gonzalez A.
Avid ACSR Elite
Dante Certified
  #30
Old 12-12-2013, 07:54 AM
So basically if my recording levels aren't clipping I'm fine?
Macbook Pro
Mac OS 10.10.3
Mbox 2,
Pro Tools 11
Question on proper levels LongRoad Tips & Tricks 11 06-14-2009 03:56 AM
rca recording levels/proper interface channel rygar22 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 08-07-2005 12:21 AM
Recording Levels jawjam 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 08-20-2004 01:32 AM
Proper recording/monitoring of vocals MarkH 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 26 08-16-2004 11:15 PM
*Recording Levels* mentalmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 08-03-2002 09:10 AM
