Garge Band files --> Pro Tools??
What is the best way to transfer or import audio files from Garage Band into Pro Tools?
Re: Garge Band files --> Pro Tools??
1) Solo each individual track, export the entire song. Solo the next track, do the same, etc... Then import all of those files/tracks into Pro Tools.
2) If the session isn't too crazy... right click (ctrl click) on the garageband file, show package contents, go to the "media" folder... There are all of the audio files in the garageband session. You can then take those and place them in Pro Tools, but you'll have to reassemble the session. Good luck. -Ryan
-Ryan Young •2019 Mac Pro 3.5 GHz 8-Core Intel Xeon W - 48 GB 2666 MHz DDR4 (OS 10.15.5) •HD Native PCIe, HD Omni, 192 I/o, Pro Tools Ultimate •Avid S3 + Dock •Blackmagic Intensity Pro (HDMI) •5.1 Room with JBL LSR4300 series
There is a better and faster way.
Open the garage band session and.... 1...Press the lock button on each track that you want to export. 2...Press play, a dialog comes up indicating that the tracks are being locked. In this case Garage Band is rendering the files. 3...Save the Garage Band session 4...Create a Pro Tools session 5...Swap to the finder and Locate the Garage Band File that you saved in step 3. 6...Right click on the file to show the contextual menu and select "Show package Contents" 7...A folder will open that contains other folders, open the "Freeze Files" folder select all and drag the contents to the edit window of Pro Tools session you have created. This will import the audio files and create a track for each audio file. Make sure all files start at the same time, say the beginning of the session. 8...Take note of the Tempo of the Garage Band file and match it in Pro Tools. You are done. You can rename the imported Tracks and files from within Pro Tools as these are copies of the files that are in the Freeze files folder. Hope this helps Simon L. |
Simons method is just fine - just notice that these freeze tracks are rendered before channelstrip fx (prosessing) and level - strangely enough not like in Logic Pro 8, that include this. If you want to include the effects and level settings used in GB, use Ryans first description (take some time, tho...). Just a choice.
pthd9-pt11 imac 14,1 / imac 7,1 / macbook air 5,2 / self-built hackintosh with gigabyte z97x board + quad i7-4690 |
Pro Tools 10 for a band | Subverse | Pro Tools 10 | 5 | 02-15-2013 09:24 AM |
Pro Tools and Garage Band | tomyco | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-07-2011 08:30 AM |
Pro Tools and Garage Band | caine27 | General Discussion | 1 | 10-10-2011 05:09 PM |
Garage Band MIDI files into Pro Tools LE 7.4.2 | munit54 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 05-05-2009 10:00 AM |
Garage Band with Pro Tools LE 7? | sjmagri | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-18-2006 11:55 PM |
