Old 02-23-2010, 08:10 PM
megasound88 megasound88 is offline
Default MP3 Bounce problem
Hi people,I use Pro Tools M-Powered 7.3.1 with Fast Track USB.When I bounce in wav format there isn't any problems with the quality,but in mp3 the highs are smashed I've checked the settings and everything seems to be fine /24 bit,320 kbps/.Is there any solution of the problem ? Did you have problem like this before ?
Thanks in advance
Old 02-23-2010, 08:36 PM
Shatzer Shatzer is offline
Default Re: MP3 Bounce problem
The problem with Mp3 is that the file size is really small compared to a .wav that when it gets compressed down it needs to filter out things to make it so small. This can very well include certain frequencies that you could hear before. When you talk about smashed, what exactly do you mean by that? It has a compressor/limiter sound that is being "smashed" by the dynamic processing or do you mean the highs are just missing?
Old 02-23-2010, 08:57 PM
Some of the highs are just missing,everything over 10-11 khz.For example the cymbals doesn't have their brilliance,they sound harsh,and in wav format everything is just fine
Old 02-23-2010, 08:59 PM
can you post all your exact settings you used to export your mp3?
Old 02-23-2010, 09:06 PM
yeah,encoding speed:fastest,constant bit rate 320 kbit/s,bit depth 24 bit,44100 khz
Old 02-24-2010, 09:54 AM
I think the problem is the operating system...I'm on Windows XP SP2,and tried with cubase and other audio interface and the result was the same...What can I do ?
Bounce Problem rjh 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-19-2010 01:28 PM
Bounce Problem paulrgmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 04-16-2009 01:35 PM
Bounce problem theogood 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 05-31-2006 05:39 PM
Bounce Problem ThadMac 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 03-08-2006 06:35 AM
Bounce problem... saltine 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-04-2003 07:42 PM
