Old 09-29-2014, 09:12 AM
crazy_ow's Avatar
crazy_ow crazy_ow is offline
Default Pro Tools 8HD won't connect with Control 24
Hi
I've just got the studio and fired everything up and my Control 24 won't work. I just keep getting a message from Pro Tools saying:
'Pro Tools can not communicate with Ethernet unit "CNTRL|24". Please power cycle the units and check connections. If units are connected, communication will resume automatically.'
I have turned everything on and off and restarted several times to no avail, I was using the Control 24 yesterday with no problems as I have done since I bought the unit, so I don't know what has happened.
It has had a power supply issue over the past couple of weeks and it has taken 5-10 mins to power up each day but despite that it has been working fine, it just wont connect to PT for some reason
If anyone can offer any advice on how to solve this it would be much appreciated as I really need to get it back online.
Loud Noises Production
www.loudnoisesproduction.co.uk
Old 09-29-2014, 09:36 AM
YYR123's Avatar
YYR123 YYR123 is offline
Default Re: Pro Tools 8HD won't connect with Control 24
Does the utility mode work? Vegas mode?
Daniel
Old 09-29-2014, 09:57 AM
crizdee's Avatar
crizdee crizdee is offline
Originally Posted by crazy_ow View Post
Hi
Try turning the mac on without the control 24 connected, then turn off again, then try connecting the control 24 and powering up the mac.
or try re-setting the Pram on the mac (Google search Pram)
Is the ethernet lights on the back of the control 24 both lit... one orange and one green. when connected to the mac and both turned on?
have you reset the control 24
run the pro tools installer again to re-fresh the driver bundle. this won't remove or effect your sessions in any way it will just replace the PT files.
chris
Producer, Engineer,
www.ukmastering.com
Old 09-29-2014, 10:57 AM
crazy_ow's Avatar
Thanks for the quick replies, all fixed!
I turned everything off reconnected and powered up all my PT hardware along with Avids guide lines and then reselected the Control 24 in the peripherals and everything seems to be working again.
How to connect Control 24 to Macbook Pro jbmoonshine Third Party Interfaces 2 05-06-2013 08:28 AM
Can not connect control 24 pro tools 6.9 Isengard ent ICON & C|24 4 02-22-2011 04:35 PM
Pro Tools HD without a mixer or control surface. Ways to connect to your monitors Intini Pro Tools TDM Systems (Mac) 42 01-09-2009 04:32 AM
How Do you Connect The Control 24 to 4 192's? Ghieri ICON & C|24 2 04-30-2006 11:23 AM
connect control 24 to my MAC cookie ICON & C|24 3 12-30-2003 07:10 PM
