Old 06-11-2014, 12:19 PM
Barry Johns Barry Johns is offline
Default Some Faders or Buttons Randomly Loose Connection
I have a Fader Pack, An Edit Pack, and a Main Unit Procontrol.
Occasionally the following occurs, if I turn the power off and back on, all units work perfectly.
Fader stops responding, moving the physical fader, or the DAW fader causes neither to respond. If I nudge, the new fader works perfectly so it is attributed to that fader. However, it does not consistently happen with the same fader, it can be random. Again, power off, then back on, all works perfectly.
The same happens with insert buttons not he fader pack, never on the main unit. So lets say I select eq on a channel, it should bring up any eq plugin on that channel. It will work perfectly on channels on the main unit, but none of the Fader Packs channel strips respond, acts like its just locked up. Again, powering down and back on solves the issue. This issue does not happen at the same frequency as the problem above, actually last night was the first time.
All units are connect to a Ethernet Hub, main unit connected via cross over cable, others a regular cat 45 cable.
Hub connect directly to the MacPro.
Any ideas?
HD Native Pcie, PTHD 11, PT12 Vanilla, Omni, Lynx Aurora 16, 192 I/O (16 in/8 out), 24 Fader D-Command, lots of preamps and compressors.
MacPro 5.1 (12) Core (2009 MacPro 8 Core Upgraded to a 12 Core MacPro), 56 Gig Ram, SSD System & 3 - 2TB Drives, OSX 10.9.5, Windows 10 Via Bootcamp
Old 06-14-2014, 01:40 PM
Delta Music Belgium's Avatar
Delta Music Belgium Delta Music Belgium is offline
Default Re: Some Faders or Buttons Randomly Loose Connection
Why do you use a cross over cable for the ProControl Main Unit? This is not correct.
All cables from all ProControl units to the ethernet hub and from the ethernet hub to the Mac should be standard CAT 4, 5 or 6 patch cables. Only if you connect one Main Unit directly to the Mac you should use a cross over cable. This is explained in the manual of the ProControl Main Unit.
My 48 channel ProControl uses only standard CAT 5 patch cables and works like a charm!
So maybe changing that one cross over cable to a standard patch cable could solve the problem.
If this does not help I would start with re-seating all CAT cables...
Then I would start to swap CAT cables...
Then I would replace all CAT cables...
Then I would try a new Ethernet hub...
If nothing of the above helps then I'm afraid it's time to start opening some ProControl units...
Please feel free to contact me privately if you would get to this stage, maybe I will be able to guide and help you (I know my machines inside and out)
Marc Schellekens
Delta Music Belgium - Dolby Atmos Music Studio
https://www.deltamusic.be
Mac Pro 2019 - 3.2GHz 16-core - 96GB RAM - macOS 14.4.1 - PT HDX3 - Pro Tools Ultimate 2024.3.1 - Avid HD I/O 16x16 (x2) - Avid HD I/O 16x16 Digital - Digidesign 192 I/O - Digidesign 192D I/O (x3) - Avid SYNC HD - Apogee Big Ben - Apogee Rosetta 200 - Avid S3 - Slate RAVEN MTi2 (x2) - iConnectivity mioXL (x4) - Genelec ‘The Ones’ 9.1.6 Dolby Atmos Music monitoring (AES/EBU) with 8341A (x5) + 8331A (x10) + 7360A (x2) + 9301B - Almost all available AAX-DSP plug-ins
Control|24 randomly moving faders ryankingsmith ICON & C|24 4 11-23-2010 08:05 PM
Faders 9-16 move randomly... ClickRec ICON & C|24 55 07-21-2010 01:15 PM
MBOX 2 USB connection Loose! help mfaktr 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-06-2008 12:04 PM
Orig MBox Loose USB Connection. Any Suggestions? Matt Foglia 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-22-2007 12:00 PM
002-Randomly losing firewire connection! audiopunk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 04-28-2007 10:23 PM
