Old 07-04-2013, 05:47 PM
guitaramundo guitaramundo is offline
Default simultaneous inputs?
hey all,
I can get a stereo guitar to record wet onto a track. Now I want to (at the same time) record a speaking vocal via the mic input on the front to a different track. I can do this no problem thru my 002 Rack by connecting the Eleven rack Via s/pdif.
just wondering if I can skip the 002 or will the mic'd signal also have the patch values...?
Thanks,
Jeff
Old 07-04-2013, 06:30 PM
Default Re: simultaneous inputs?
Originally Posted by guitaramundo View Post
hey all,
Thanks,
Jeff
Yep, and this is trivial to do. And the Eleven Rack documentation should make all this clear and is the best starting point (its is actually very well written and useful).
Any one of the inputs (guitar in, line in, Mic in, digital in, or the special internal "reamp".. which is really an output) can be used as input to the virtual rig processing. Guitar in, line in, Mic in and digital-in are also all available as inputs in Pro Tools, regardless of which one is used to drive the virtual rig inside the Eleven Rack.
Your IO when using an Eleven Rack should be showing a mono mic input, a mono dry guitar input, and a stereo guitar out, etc.. If not default the input settings in Setup>IO. I suspect you just have the 003 IO defaults and so not seeing what you want to on the Eleven Rack. All this should be stupidly easy once you do that, but if its not workign explain exactly what you are doing, ideally provide screen shots of track input settings and setup>IO>Input etc. And provide all the useful info asked for, see "Help us Help You - READ THIS Before Posting!".
Darryl
Old 07-08-2013, 01:37 AM
Thanks Darryl,
I can see the inputs in the IO but other than the guitar input they are greyed out. Now that I know this should work I'll dig deeper.
Thanks for confirming for me!
Jeff
Old 07-08-2013, 04:33 PM
Benoni's Avatar
Benoni Benoni is offline
Thanks Darryl,
Jeff
Did you click Default in the IO?
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Old 07-08-2013, 04:59 PM
"... ideally provide screen shots of track input settings and setup>IO>Input etc."
Those screen shots will also help if you are still stuck.
Simultaneous inputs with Avid HD I/O cc1984 General Discussion 16 05-21-2011 06:05 AM
002 Rack Simultaneous Inputs mars 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-03-2003 04:55 PM
002 Simultaneous Inputs hitshack 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-06-2003 08:25 PM
multiple simultaneous inputs ether 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-18-2002 01:18 PM
How is this 18 SIMULTANEOUS inputs again? BHeller 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-26-2001 12:56 AM
