Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Mac)
Old 05-11-2013, 01:06 PM
chritaro chritaro is offline
Default Mbox Pro Firewire Not Recognized (Light Show)
I'm having a issue, and as far as I have seen in other threads at the forum, it's a rather common one. My Mbox Pro was doing fine, but suddenly stopped being recognized by my Macbook (Snow Leopard 10.6.8), and didn' t even show up anymore on the System Preferences Sound Window.
If Macbook was rebooted, Mbox returned to normal for a few minutes, only to repeat the problem over and over again. While using a program like Pro Tools, or even a generic app for listening to music, it was possible to perceive the connection being lost.
I then remembered that the problem started just after I' ve installed a software called Soundflower, from Cycling 74, which routes audio signal from a software to another. Just as a experience, I tried to uninstall Soundflower to see if it had some effect over the Mbox behavior, and - surprise, surprise - the problem was solved.
But that' s not the end of the story... A few days later, I tried to install Logic Pro 9 on the same machine. I have more than one software for audio running there, and was trying to implement this one too. Logic produced the same effect as Soundflower, and my Mbox vanished from the system after a few minutes.
Again, the solution was uninstalling Logic, and fortunately all is running well as before I tried to use this softwares.
Now, my question is: what is causing this problem? I know that Mbox can be used with Logic and Soundflower, because I have seen it working in other Macs. What can I do to solve this, if it happens again (even with other softwares)? This is obviously a software issue, since now my system has worked well again all week.
Thank you for your help!
Mbox led light show - hardware not connected tomvdd 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-04-2013 09:16 PM
Mbox 2 Pro not recognized by Macmini's firewire 800. Only flashes. danthepianoman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-10-2012 08:51 PM
Just bought a Mbox 2 mini, usb light doesnt light up/installation stops progressing? DjRybe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 12-27-2009 05:55 PM
MBox 2 pro not recognized, blinking light JonesH 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-03-2007 02:10 PM
Interpol's light show Erik Braund General Discussion 0 02-08-2007 10:27 PM
