64 sample hardware buffer gone in 8.0.3
Please forgive me if this is a stupid question, but I've done lots of searching and can't find the answer.
I used to have the option to set my h/w buffer to 64, and now with 8.0.3 it is gone. Was there a "read me" or announcement that I missed? I've noticed it on an Hd3 on 10.6.2, on a hd2 on 10.5.8 and on my LE on 10.6.2. Did this disappear before 8.0.3? |
Re: 64 sample hardware buffer gone in 8.0.3
Its related to your playback settings for number of voices per DSP's Chris
2016 MacBook Pro Retina | 16GB RAM | 1TB SSD | OS X Latest - PTHD 12 Latest | 4K LG Thunderbolt Display | Logic Pro 10 |
Thanks, guys. So it seems:
if I set the Number of Voices to 96 (2 DSP) I can go to HW buffer of 64. If I set to 64 Voices (2 DSP) I can only go to 128. If I set to 32 Voices (2 DSP) then I can only get to 256. I suppose this makes some kind of sense. It's just odd that I never noticed it before. |
The lowest possible buffersize is indeed related to the number of DSP chips and the number of voices. Have a look at this: Number of Voices / DSP chips / Lowest buffer size 192 / 6 / 128 144 / 6 / 256 96 / 6 / 256 160 / 5 / 128 120 / 5 / 256 80 / 5 / 256 128 / 4 / 128 64 / 4 / 256 96 / 3 / 128 48 / 3 / 256 96 / 2 / 64 64 / 2 / 128 32 / 2 / 256 48 / 1 / 64 32 / 1 / 128 16 / 1 / 256 Best regards, Ad |
I´m kind of curious with that f.e. why should I choose 48 / 3 / 256 instead of 48 / 1 / 64, loosing 2 chips AND getting higher latency (= less performance) ? are there any other benefits ?
MP5,1 12core 3.46ghz 96GB Ultimate HDX https://www.youtube.com/channel/UCIA...Rnu0Jfh-YsgftQ |
From that chart it looks like 96/2/64 is the way to go for most situations.
The playback engine settings for voices and dsp chips define how much stress you put on your PCI/PCIe bus (you can watch it in the System Usage Window). Many voices on few DSPs take more bandwidth.
My standard setup is 96 voices on two DSPs, works well with many sessions. AFAIK you have to be careful with these settings if you use an expansion chassis or other stuff that uses the PCI/PCI-e bus extensively. But I didn't know that the possible buffer size settings depend on the voice/DSP-setting... Mark
Mac Pro 2010 3.66 GHz six Cores, HD Native, 192 I/O, Avid Dock, Artist Mix and Pro Tools Ultimate Mac mini 2018 i5 64 GB RAM, RME Fireface, Pro Tools 2021, Euphonix MC Control MacBook Air 2020 (M1) 16 GB RAM, 1 TB SSD, Zoom U-44 and Pro Tools Ultimate |
How to track with 32 or 64 sample buffer? | kirkbross | Pro Tools 11 | 24 | 11-08-2013 04:07 PM |
32 sample buffer size? | CamM | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 08-30-2009 08:16 AM |
Is there any way to get a 128 sample buffer with an Mbox ? | Ru_C | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-10-2008 09:20 AM |
Hardware buffer size in relation to DAE buffer | sricabla | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-04-2006 10:30 AM |
Is everyone able to run at 128 sample buffer size? | lwilliam | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 11 | 05-04-2001 06:59 AM |
