ilok Auths not working properly *DELETED*
Post deleted by ajv205
Re: ilok Auths not working properly
Repair your disk permissions.
repairing the disk permissions did not fix the problem. any other ideas??
install the latest iLok drivers from the iLok website, see if that helps -it's possibly your system is not seeing hte iLok because it's not installed
I had a similar problem in the past and repairing disk permissions with the utility didn't help. I had to manually give full access back to each of my drives since the utility actually gives limited rights. |
You can Read & Write (greyed out) Details: Owner: system Access: Read & Write Group: admin Access: Read & Write Others: Read only I hit "apply to enclosed items" and it says operation could not be completed because I don't have sufficient priviledges for some of the items. I did notice that the System folder (the one with the "blue x on it" is the same as the Mac HD EXCEPT Group is "wheel" and that is "read only". could that be it? I dont want to touch it if yours says the same. |
I had this issue recently too. Never could get it figured out, a re-format and fresh install of the OS + all my software was the only way I could get back to normal.
I would go to each of your HD's and unlock them then set the the permissions and relock them. After that reinstall your iLok related plugs and the most recent Interlok Extensions. |
Moving PT 10 auths to different iLok WITHOUT replacing PT 9 auths = maddening | drguitar | macOS | 6 | 01-15-2012 10:01 AM |
ILOK auths when usin' 7.4 and 8.0?? | mykhal c | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 08-28-2009 05:36 PM |
Can some TDM & LE iLok auths be used either way? | chuck.dallas | Pro Tools TDM Systems (Mac) | 1 | 03-04-2006 06:05 PM |
Waves iLok auths | Chris Coleman | Pro Tools TDM Systems (Mac) | 10 | 11-26-2005 08:50 AM |
PT6 / ILOK Auths...No Updates Yet... | soundlife2 | Pro Tools TDM Systems (Mac) | 6 | 02-28-2003 07:51 AM |
