  #1131
Old 05-27-2008, 02:42 PM
mykhal c's Avatar
mykhal c mykhal c is offline
Default Re: Best Core 2 Series Desktops-Results and Specs
mykahl,
What would you recommend for timing of this RAM? web page
Like Guitardom, I set the timings according to the first page of this thread--5-5-5-15.
Thanks.
from your link...
Tech Spec
Capacity 2GB (2 x 1GB)
Speed DDR2 800 (PC2 6400)
Cas Latency 4
Timing 4-4-4-12
Voltage 2.1V
Heat Spreader Yes
Features SLI certified
Recommend Use High Performance or Gaming Memory
typically the DDR2 800 ram is designed to run at the tighter timings of 4-4-4-12. sunburst's post on page 1 is for those with DDR2 1066 ram whose timings typically have to be set looser, 5-5-5-15. so for your DDR2800 you should see a performance gain with the tighter settings of 4-4-4-12. hope that helps
bassist...deep pocketz anyone???!!!
The Basschakra Lucid Soul Trip
i7 Builds - Specs and Results
HDNative | Omni | i7-3930K OC'd 4.0GHZ |
ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff
  #1132
Old 05-27-2008, 02:50 PM
Teolin Teolin is offline
I'll try it. Thank you. I'm sneaking out of work right now...
Pro Tools 12.4
HDN, PCIe, Omni & Digi 192
ASUS Sabertooth, Intel i7 3820 3.6Ghz
32 GB 1600Mhz Corsair RAM
SSD 500GB Samsung
WIN 10 64bit
  #1133
Old 05-27-2008, 03:13 PM
mushkin ram
it does say 4-4-4-12 for specs. i do have it at 5-5-5-15 now. am in the middle of some 250 gig data transfer of my sample drive, so will be a bit before i can fix it
are there other settings on the first page i should be aware of that might be different for me?? other bios tweaks that should be done early on?? i believe i mentioned i have a p5k-e. just want to get this thing rockin'!!!thanx for your help!
oh and i am using a bla modded 002. 7.4 cs4
pro-tools-pc.com
TRASHER Pro Tools Utility(updated 4-11-2024)
Intel I7 9900k
Win 10
  #1134
Old 05-27-2008, 04:22 PM
mykhal c's Avatar
mushkin ram
no that's really the only one that is unique to DRAM speed. you should be good and rockin' on everythin' else!!
  #1135
Old 05-27-2008, 10:45 PM
finally finished all the drive transfers i had, then went to work!!
changed the ram settings, basic os tweaks, nothing crazy, and sunbursts bios settings from the first page.
hit 238-239 d verbs!!!! much happier and a bit calmer now!!
interested in overclocking a bit maybe soon, but in good shape. got a few more things to install then should be in good shape.
have not tried it with all my plugs installed, pulled them out for this test.
thanks guys, and glad to join the team
feels weird to leave the quadzilla page, been there since day 1....
pro-tools-pc.com
Intel I7 9900k
Win 10
  #1136
Old 05-28-2008, 12:39 AM
mykhal c's Avatar
welcome!! glad you are tweaked and dialed in!! and remember you're only a thread away from your first stompin' grounds!!!!
post your full build/specs and i'll add you to the page 1 builds
  #1137
Old 05-28-2008, 04:19 PM
mlickiss mlickiss is offline
Just wanted to say thank you to everyone who has posted their builds, I was no longer even able to run Pro Tools on my little P4 without errors popping, now I ran a rough reverb 2.0 test (I did not remove my other plug-ins including my VSTs) and got around 250 without any kind of overclock (I don't trust myself). Sunburst and Mykhal-I cannot say thanks enough. I am a computer building noob and would have been at an absolute loss without reading the great advice on this post. I could not be happier.
Thanks again-
Lickiss
Q9450
4 GB Corsair Dominator 1066
Asus P5k
Sony Optiarc DVD/CD Ligthscribe
Seagate barracuda Sata 250GB - System
Seagate barracuda Sata500 Gb - Audio
Biostar GE force 8400 256MB
Rosewill Tower w/ 450W power
  #1138
Old 05-28-2008, 04:35 PM
mykhal c's Avatar
Thanks again-
Lickiss
Q9450
Asus P5k
excellent and congrats!! i'll add ya to the list so others can benefit also btw, which version of PT and which interface?? thanks!!!
  #1139
Old 05-28-2008, 05:13 PM
7.4 with the music Production toolkit. The test was done with an old MBOX, at my main place I have an 002Rack, I will post those numbers when I actually get up there.
Thanks again.
  #1140
Old 05-28-2008, 06:37 PM
asus p5k-e
q6600
arctic cooling freezer pro 7
corsair 620hx psu
mushkin ddr2 800 pc2 6400 4 GB
asus en7300gt silent 256mb
seagate 80GB system drive sata 3.0
wd raptor 10,000 rpm 74GB audio drive
seagate 500GB samples drive sata 3.0
p link 4 space rackmount case
pro tools 7.4 cs 4 w/ mptk
002
239 d verbs.
which has me curious, how are you guys hitting the 250 and above!!!???
pro-tools-pc.com
Intel I7 9900k
Win 10
i7 Builds - Specs and Results mykhal c Windows 7144 04-15-2024 12:10 PM
Intel Quad Core vs. i-series solidwalnut 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 11-23-2010 05:16 AM
Have a Quad Core (Asus P5K). Use Only One Core Active For Best Results? MIDI Issues. epu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 08-12-2009 02:24 AM
are these specs ok? (low budget 2 core) korkman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 08-22-2008 02:44 AM
8 Core Mac Pro, Leopard and Windows results pasanta 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 01-13-2008 06:51 PM
