Focusrite Liquid Saffire 56
Ok- so who has used this box before......??
Is it any good? Nice coverters? Nice pre's (at least on the two liquids)? If I have to jump back to LE I am gonna needs some thing along these lines....??
Re: Focusrite Liquid Saffire 56
It's a great unit, I love mine.
D a n t h e I n c r e d i b l e S o u n d M a n "Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4 Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0 _C U R R E N T-D V E R B-S C O R E:515 |
So did you ever do a a/b with whatever avid interface you have/had? What did you think? The whole HD voicing i need another card issue is not fun
I noticed an immediate difference from my 003 in both DA and AD. Has a great list of features, and more I/O than any Avid interface.
Dan, hey I was wondering what sample rate u record at? Also have u smux'd adat's in more than 48k?
Do u have to set the inputs thru the DSP mixer every time u want to record (into pt) or does it remember the setup?
focusrite liquid saffire 56 problem
hello everybody
i am new to forums , i hope i am in the right place. i have a problem with my liquid saffire 56 interface, i tweaked all my system . system:- processor : intel core i7-2600K CPU @ 3.40 GHz RAM : 16GB DDR3 VGA card : ATI Radeon HD 5870 Os: windows 7 ultimate 64bit i had to buy a firewire card , and when i run the OHCI tool .. it says Vendor : (104C) Texas Instruments Chipset: (8025) TSB82AA2B/TSB83AA22A/TSB83AA23 Revision: 01 Max 1394 Speed Capability: S800 Support: Compatible, no known issues. Done. so it is supposed to be compatible , though when i run mix control 3 . it gives me .. no hardware connected , although everything is plugged , sometimes it is connected sometimes it just disconnects. mainly after i open PT10 everything is updated , all the drivers .. i cant seem to know what is causing the problem .. i would really appreciate some help thanks all |
So when you have your Saffire 56 plugged-in what does your device manager show for the sapphire 56?
hello
the computer recognizes the the saffire 56 . and it works smoothly with pt 10 for a while at least .. and mix control 3 opens .. then all in a sudden .. the saffire seems to disconnect. i have to restart my computer for it to get recognized again. |
MixControl always remembers everything. You can save up to 250 different profiles or something like that.
Focusrite Liquid Saffire 56 | muzicmaken | Pro Tools 10 | 0 | 03-31-2012 09:17 PM |
Focusrite Liquid Saffire 56 | YYR123 | Pro Tools TDM Systems (Win) | 7 | 11-16-2011 11:57 AM |
Focusrite Liquid Saffire 56 | YYR123 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 11-12-2011 11:31 AM |
Focusrite Liquid Saffire 56 and PT 9 ? | trock | Pro Tools 9 | 5 | 09-19-2011 04:27 PM |
I/O from Focusrite Liquid Saffire 56 in PT9 | PUMASALAD | macOS | 7 | 04-14-2011 11:31 AM |
