Old 09-29-2010, 02:29 PM
hodge hodge is offline
Default "ride" the faders?
can someone explain exactly how to do this? Do you do this to adjust leveles during the bounce? ANd can i do it using my projectmix?
Old 09-29-2010, 04:20 PM
ondruspat ondruspat is offline
Default Re: "ride" the faders?
The term "riding the faders" comes from the days of mixing on a console before they had automation. The volume faders were manually adjusted when the tracks were bounced down to the final mix.
You can use automation on your volume faders to achieve this.
"Sometimes having limits keeps you sane"- Albee1952
Old 09-29-2010, 04:25 PM
ok cool, is this a some what new feature (past year or so)? For some reason i thought you couldnt do that with protools
Old 09-29-2010, 04:33 PM
As far as I know you have always been able to do this in PT (at least all the years that I have used it). Just read up on automation in the reference manual.
Old 09-29-2010, 05:05 PM
Yes indeed. Just put the track's automation in TOUCH mode and grab that fader. If select to view VOLUME in the edit window, you can see the line turn red whenever your finger is controlling the fader(even if you don't actually MOVE it
Old 09-29-2010, 11:23 PM
Matts Matts is offline
Yeah, but you can't _manually_ "ride" the faders _while_ bouncing, can you - if that's what the original poster had in mind?
(You can however accomplish this, to manually "ride" the faders, if you forget about the actual bounce command, and record to a new track instead.)
-matts
Old 09-30-2010, 12:10 AM
DrFord's Avatar
DrFord DrFord is offline
Correct, you cannot adjust faders during a bounce. You set all your automation params BEFORE you bounce to disk. Dial it in, get it right... THEN bounce to disk when you want a final version.
All mixing commands are automatable in Pro Tools (all versions.) Hold down control + option + command + click and you will get a quick menu drop down which says "enable paramater". If you say yes, it will give you an automation lane living in your edit windown, next to playlists.
DRFord
Homepage | Facebook | YouTube
Mac OSX 10.12.6 | Mac Pro 5,1 | 12core 3.46ghz
Avid HD Native PCIe Core | Pro Tools HD 2018.1
Old 09-30-2010, 06:41 AM
-matts
Tthis is true, and here's the workaround broken down(if you just feel the need to ride faders all the way to the end). Bus all your tracks to a new stereo bus, create a new stereo AUDIO track with the input set to that same bus, put the new track in record and go. Now you are creating a final 2mix where you CAN ride the faders.
Old 09-30-2010, 01:09 PM
"The cool thing about digital is; there's 4 ways to do everything. The bad thing about digital is; there's 4 ways to........... "
Old 10-02-2010, 04:33 PM
Mikeren Mikeren is offline
I'll see you and raise you one
Learn to listen. Listen to learn.
Does "Westmere" qualification apply to "Bloomfield" and "Gulftown" also? bashville Pro Tools 10 5 03-23-2013 03:04 PM
is there "delay compensation" for writing automation via faders?? anotherchrisperry Artist Series 19 10-01-2012 05:45 AM
Feature Request: Assignable "Midi faders" Xill Artist Series 4 10-29-2011 11:15 AM
hardware buttons for "preview", "capture" and "punch" evs Post - Surround - Video 1 12-06-2010 12:28 PM
Control 24 loss of Faders "possible power supply problem"? Kevin101 ICON & C|24 1 01-23-2003 09:34 AM
