Old 02-23-2020, 08:27 AM
jgod330 jgod330 is offline
Default Trouble installing ProTools | First 2019.5
Summary
New user here, so apologies if this is posted in the wrong place.
  • Trying to install ProTools | First in order to get familiar with the program. Only using my PC with ASIO software / no audio interface.
  • I have tried many times to install both ProTools | First 2019.5 and 2019.5 (ran as "administrator") but no luck. They both fail at the end of the installation process. Screenshots below.
  • I believe my computer meets all ProTools | First system requirements. Details below:
SiSoftware Sandra Report
Computer
Model : Dell XPS 15 9570
Serial Number : ****
Chassis : Dell Notebook
Mainboard : Dell 0D0T05
Serial Number : ************
BIOS : Dell 1.14.0 11/08/2019
TPM - Trusted Platform Module : NTC NPCT75x 2.0 (PCR 24)
Intel vPro : 12.0.47.1524
Total Memory : 7.75GB SO-DIMM DDR4
Processors
Processor : Intel(R) Core(TM) i7-8750H CPU @ 2.20GHz (6C 12T 3.71GHz/4.1GHz, 3.4GHz IMC/3.8GHz, 6x 256kB L2, 9MB L3)
Socket/Slot : FC BGA1356/1528
Chipset
Memory Controller : Dell Core8H (CofeeLake-H 6C) Host Bridge/DRAM Registers 100MHz, 2x 4GB SO-DIMM DDR4 2.67GHz 128-bit, Integrated Graphics
Memory Module(s)
Memory Module : Samsung M471A5244CB0-CTD 4GB SO-DIMM DDR4 1Rx4 PC4-21300SO DDR4-2666 (19-19-19-44 7-63-21-7)
Video System
Monitor/Panel : SHP Generic PnP Monitor (1920x1080, TK6R7€LQ156M1, 15.5")
Monitor/Panel : Hewlett Packard HP 22cwa
(1920x1080, 21.7")
Video Adapter : Intel(R) UHD Graphics 630 (24CU 192SP SM6.4 1.1GHz, 768kB L2, 4GB DDR4 5.33GHz 128-bit, Integrated Graphics)
Graphics Processor
CUDA : nVidia GeForce GTX 1050 Ti with Max-Q Design (768SP 6C 1.42GHz, 1MB L2, 4GB 7GHz 128-bit)
OpenCL : nVidia GeForce GTX 1050 Ti with Max-Q Design (768SP 6C 1.42GHz, 4GB)
OpenCL : Intel(R) UHD Graphics 630 (192SP 24C 1.1GHz, 512kB L2, 3.1GB DDR4 5.33GHz 128-bit, Integrated Graphics)
D3D 11 : NVIDIA GeForce GTX 1050 Ti with Max-Q Design (4GB)
D3D 11 : Intel(R) UHD Graphics 630 (192SP 24C 1.1GHz, 768kB L2, 128MB DDR4 5.33GHz 128-bit, Integrated Graphics)
OpenGL : GeForce GTX 1050 Ti with Max-Q Design/PCIe/SSE2 (4GB)
Storage Devices
PC401 NVMe SK hynix 512GB (512.1GB, PCIe/NVMe) : 477GB (C:)
Logical Storage Devices
OS (C:) : 461GB (NTFS, 4kB) @ PC401 NVMe SK hynix 512GB (512.1GB, PCIe/NVMe)
WINRETOOLS : 990MB (NTFS, 4kB) @ PC401 NVMe SK hynix 512GB (512.1GB, PCIe/NVMe)
Image : 13GB (NTFS, 4kB) @ PC401 NVMe SK hynix 512GB (512.1GB, PCIe/NVMe)
DELLSUPPORT : 1GB (NTFS, 4kB) @ PC401 NVMe SK hynix 512GB (512.1GB, PCIe/NVMe)
ESP : 646MB (FAT32, 4kB) @ PC401 NVMe SK hynix 512GB (512.1GB, PCIe/NVMe)
Peripherals
LPC Hub Controller #1 : Dell C240 Series Chipset Family LPC Controller (CM246) - A30E
Audio Device : Dell Cannon Lake PCH cAVS
Disk Controller : Dell Cannon Lake PCH Shared SRAM
Disk Controller : Dell Mobile SATA RAID Controller
USB Controller #1 : Dell Cannon Lake PCH USB 3.1 xHCI Host Controller
USB Controller #2 : 8738 JHL6340 Thunderbolt 3 USB 3.1 Controller (C step) [Alpine Ridge 2C 2016]
SMBus/i2c Controller #1 : Intel ICH SMBus
Network Services
Network Adapter : Bluetooth Device (Personal Area Network) #2 (Ethernet)
Network Adapter : Realtek USB GbE Family Controller #2 (Ethernet)
Wireless Adapter : Killer Wireless-n/a/ac 1535 Wireless Network Adapter (802.11ac (VHT), AES-CCMP, 866.7Mbps)
Power Management
Battery #1 : SMP DELL GPM0365 97.00Wh/7.84Ah
Operating System
Windows System : Microsoft Windows 10 Personal 10.0.18363
Platform Compliance : x64
Installation Experience
Install appears to be going just fine. See screenshot: https://imgur.com/r0i0sB0
Then I get to this part, which I assume is the final step. See screenshot: https://imgur.com/cN2Lq1x
Then...nothing. Program does not install. Have restarted computer several times but the program does not appear.
Please help and let me know if I can provide more info. Many thanks!
Old 02-23-2020, 11:46 AM
Default Re: Trouble installing ProTools | First 2019.5
Hi, welcome to the community.
Moving to First subforum
Old 02-24-2020, 08:26 AM
junkgear's Avatar
junkgear junkgear is offline
Your system looks fine for running PTF.
Have you created your iLok account and is the iLok connected to your computer?
I know on my Windows system, the install can appear to hang, but it actually just takes a long time for it to finish. Make sure you have given it enough time to install.
Will
System Details
Old 02-24-2020, 01:25 PM
rodno rodno is offline
In Windows I had to uninstall PTF 2019.6 then I installed PTF 2019.5 rebooted and then installed PTF 2019.6 rebooted and then it loaded just fine. Hope this helps.
Old 02-25-2020, 03:37 AM
I have created my iLok account. How can I verify it's connected to my computer?
Old 02-25-2020, 04:35 AM
Open the iLok License Manager application, many times called ILM here
Old 02-26-2020, 01:46 AM
I installed ILM to my computer, signed in, and activated my license for PTF. Tried installing PTF again and got stuck at this point again:
However, I did some digging and found the below file (file path = "C:\Users\xxx\Downloads\Pro_Tools_First_2019_5_Win _105868\Pro Tools First\Program Files 64\Avid\Pro Tools\ProToolsFirst.cat"). Tried running "ProToolsFirst.exe" but got the below error. Thoughts?
I should mention that ProToolsFirst does not appear in my Control Panel as an installed program.
Old 02-26-2020, 06:00 AM
junkgear's Avatar
CFnd.dll is a Avid library file. By clicking on the exe from that location, you are attempting to run a program that hasn't actually been installed, and therefore it can not find the files it needs to run.
You can try downloading the installer again to ensure your copy is not corrupt. Also run the installer as administrator just to rule that out.
If it fails again, see if you can find any log files that may shed some light on why it is failing to install. In file explorer, type %TEMP% into the file path section and press enter. You should see some Avid folders in there.
Will
System Details
Old 02-27-2020, 04:27 AM
Downloaded the installer again and ran as administrator. Still failed.
Pulled up the %TEMP% files and see the following:
Clicked through a few folders and several of them contain versions of the following:
How do I proceed? Many thanks, @junkgear, for your help thus far!
Old 02-27-2020, 10:12 AM
junkgear's Avatar
Does Avid Link finish installing? Do you get a menu item for it and can you run it?
Will
System Details
Trouble Installing ProTools!!! RocketDog28 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-24-2007 01:52 PM
Trouble Installing ProTools!!! RocketDog28 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-24-2007 12:41 AM
Trouble Installing ProTools LE 5.33 yeehawchicken 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-20-2006 11:36 PM
Trouble installing ProTools LE 6.4 nightmarefalcon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-24-2006 08:13 PM
trouble installing protools 5.1 le dean7 Digidesign Hardware & Software 1 01-01-2002 01:43 PM
