#21
Re: Best hard drive for recording to?
Will this thread ever introduce the word "need?"
"Dear OP, what do you 'need?'" "I never record more than 10 tracks at once, and maybe two VIs." "OK, well you don't need a Cheetah." I do a fair bit of recording which would be considered strenuous for the computer, in ADDITION to an immense amount of VI playback, and I've never had my 10K rpm drives bark at me. The key is not fast drives, it's separation of media types. Keep VI samples separate from audio, and keep video on yet another drive. Do that and there will rarely be an occasion where you'd "need" your platter spinning faster. The added money, heat, noise is just wasteful in most cases. |
#22
+1 for WD.
A lot of my work goes from MIDI to mixdown (no time for bouncing to audio). I'm talking a lot of multi-timbral MIDI and Instrument tracks setup for mixing with plugins. For several years now it's been four 32 (now 64) MB cache WD Black 7200 rpm SATA drives with 2 dedicated to sample libraries. Loading is fast enough not to make me feel a need to upgrade and performance is solid. |
#23
Thanks for your help
Raoul Crane
www.blaze-studios.co.uk PT 10.3.10 HD Accel 6, Mac Pro 5.1 12 Core 3.46hz Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis |
#24
Slower rpm usually means slower seek time, access time, write and read speed. Which will cause latency, reduce your ability to have a high count of audio tracks and vi's, as more of these will bottle neck the writing/reading speed of your HDDs. Of course you should always have an independent System drive, Vi drive and audio data drive. Making this 3 physical HD drive, not partitions.
#25
i only have 2 drives at the mo and i dont use many if any virtual instruments just superior drummer thats all so will running 2 drives be fine Cheers
Raoul Crane
#26
And I'll also recommend avoiding the green drives. I've never used them but several people have tried them and they cause problems when used for audio. You could probably do a search and find several threads on it. Including that, there's been lots of good advice in this thread.
Dell T5810. Harrison Mixbus 32C. Haven't used PT since 2015 and never been happier. |
#27
here's a good article about it. http://blog.fosketts.net/2011/04/27/...e-design-flaw/ |
#28
How many tracks will you playback and record? In most situations, especially if you're spreading the load across two drives, even 7,200rpm HDDs will be completely fine. If your track count reaches >50 then maybe you'll want to reconsider. Ultra fast seek times are BS, as is the recommendation for 15,000 rpms. Don't get caught up in the hype, unless money is no object to you. Either way, it's unlikely that you'll notice the performance potentials. |
#29
Saying it's BS doesn't mean you are right. I've had raptors before, and I had to upgrade to higher speed drive due to the sheer number of Audio track I was doing. There comes a point, if you reach it, that even 10000 rpm just don't cut it, and no amount of cache will save you when you reach the HDD limit.
#30
I've had sessions with 30 audio tracks and around 100 channels of streaming VIs working from two 7,200 rpm drives. No system sweating whatsoever. I'm relatively certain that the OP isn't taxing his system to this extent. Superior Drummer is brilliant at balancing caching vs. streaming and doesn't ask much of its hard drive. 24 bit audio at 44K or 48K is a drop in the well for modern machines. To the OP: if you buy 10,000 rpm drives and they're too slow, send me the bill -- I'll take them from you and send 15,000 rpm drives in return, my treat. |
Recording to exteral hard drive | robbie123 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 07-05-2012 07:42 PM |
Should I be looking at recording to an external hard drive? | Judicious | macOS | 24 | 06-07-2011 07:00 AM |
Recording Hard Drive | Davidwilson | Pro Tools TDM Systems (Mac) | 9 | 12-12-2010 12:52 AM |
Is this a good hard drive for recording on Mac? | bruce_pianoman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-25-2005 01:48 PM |
Best recording hard drive for 5.2 LE 0s 9.1 | FLENSER | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-18-2004 05:18 PM |
