Old 05-16-2015, 10:44 AM
c-arts c-arts is offline
Default Kind of Bounce problem PT11 HD Native
Hi there,
i have PT 11 on a Thunderbolt HD Native card.
I often have many files to bounce from one session. (100+)
When I begin to bounce to disk with the offline function everything goes fine; the speed is with some plugins at 40x.
But after about 20 files PT starts to struggle:
I press "OK" for bouncing and then the colourful ball icon comes and the system sleeps for a moment.
It's not crashing. Then after a while it starts bouncing - at 40x again.
After the bounce process the same: the colourful ball appears until I can do the next step.
Only a restart of PT helps - then after about 20 files the same begins.
Does anyone else encounter with this problem?
I'm working on an IMac 4 GHz Intel Core i7 with 32 GB 1600 MHz DDR3
Thanks
Michael
Old 05-16-2015, 02:36 PM
Default
Grasping at straws here...do you have SLEEP enabled? Disabling that is one of the required system tweaks Does it do a real-time bounce okay? Does the iMac have a Fusion drive?
Old 05-16-2015, 05:44 PM
DetroitT's Avatar
DetroitT DetroitT is online now
Default
I've had success using Cocktail "Purge inactive memory...." to speed things up without a Pro Tools restart.
For me it's when rendering many elastic audio tracks.
(Help us Help You)<<<click here
Testing:All APFS 90% 10% Audio on HFS+(Testing 1.5 yr in)
Pro Tools U-2019.6 MacOS 10.14.6
Second boot-10.13.6 (Avid HDX-1 Omni)
(MP 5,1 / 64-Gb)
(Sapphire RX-580 MacVCEdition, 3-Displays)
MOTU FW-CoreAudio (for poly recording)
(SSL-HUI-MIDI over IP)
music-design-creation
Post Music-Sound mixing, Production-Enhancements.
Audio Tuning and System Services
Old 05-18-2015, 02:03 AM
Default
Hi there, thanks for you answers:
@albee1952: Sleep Mode is disabled! Yes, the iMac has a fusion drive!
@Darryl: I'll try that the next time!
@Detroit I'll try that too, thanks for the tip!
Old 05-18-2015, 10:40 AM
JFreak's Avatar
JFreak JFreak is online now
Default
Originally Posted by Darryl Ramm View Post
The fusion drives are suspect in causing stability problems even if not used for audio/session storage. You should have never purchased a Mac with a fusion drive for use with Pro Tools, or you should have reconfigured the fusion drive into two separate drives (but be careful of not getting a fusion drive that uses a 4,800 rpm drive). This has been discussed a lot on DUC, and instructions on how to do that are easily findable online.
100% correct.
Fusion drive is not for Pro Tools.
Period.
Janne
Old 05-20-2015, 03:51 AM
Default
I've seen this ever since offline bounce was introduced which made me give up on it.
In complex film sessions I usually have to wait for 5-10 minutes for the beachball to settle and before PT actually starts to bounce. A reel then takes about another 8-10 minutes depending on complexity and then another 5 minutes of beachball after the bounce.
In total that's actually way longer than a traditional realtime bounce.
Might be faster with small sessions but I never use offline bounce mainly because of this. (The QC aspect not even considered).
frank.
PTHDn 2019.6 (OSX10.14.4), 8x8x8, MacPro 5,1 3.33Ghz 12-Core, BM DeckLink SDI, SYNC HD, all genlocked via AJA GEN10, 48GB RAM
Old 05-20-2015, 06:41 AM
Default
Granted i am on PC, but off-line bounce works great here. In months, i have only had a single session that refused to BTD off-line, but it would offer me a button to run a real-time bounce, which worked every time. Did the OP ever answer regarding real-time bounce working?
Buffer latency compensation problem, Mackie Onyx 1640i, PT11 native Wirtanen Pro Tools 11 29 06-16-2015 10:27 AM
Can I use AAX DSP plugins with PT11 HD Native? BigDropz AAX Plug-ins 4 03-13-2014 11:14 PM
PT11 to PT11 HD Native upgrade without hardware? kirkbross Pro Tools 11 2 11-04-2013 03:10 PM
New Mac for HD Native & PT11- help!! sms1305 Pro Tools HDX & HD Native Systems (Mac) 7 05-10-2013 12:40 PM
I have kind of a stupid problem J0hn_Obrien444 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-27-2008 08:23 PM
