Old 04-03-2012, 05:25 PM
improvpwnd improvpwnd is offline
Default Create new track using 'new track' in SENDS menu - output hardware instead of bus?
When I Create new track using 'new track' in SENDS menu, the output is sent to a hardware instead of bus - but it used to not be like this. So now when I want to bus a group of tracks out to an AUX this way, it creates an inactive hardware i/o path and just deadends my workflow for until I reroute manually. Any way to change this option? I've searched the forums, the manual, and the PT drop down menus..
PT 10.0.1 on OSX 10.6.8 with an RME Babyface btw
Thanks!
Old 06-10-2012, 06:40 PM
Default Re: Create new track using 'new track' in SENDS menu - output hardware instead of bus
Bump, still need help with this..
Old 06-10-2012, 08:08 PM
albee1952 albee1952 is online now
2 solutions(aka "workarounds") that may work(but what you are asking for is really not feasible), create the track first, as we did in the days before this "new track" feature, or build yourself a session with these custom features in place, and instead of creating the new track, go to File>Import Session Data and import the appropriate track from your custom "source" session. I use this method when adding an Instrument track for DB-33. When I simply add DB-33 to a session, none of the controls are mapped to my VOCE drawbar midi controller, so by importing the pre-mapped track/plugin from a pre-built session, allows the imported Instrument track to operate with all mapping in place.
After further thought, are you forgetting the option that is presented where you can choose the kind of "new track" you are adding? When I use the Send>New Track function, I can choose mono or stereo, AND between audio and AUX type. Or am I not understanding something?
Old 06-25-2012, 06:15 PM
The type of track it creates (AUX vs AUDIO vs Instrument) is fine, it's just the default route it chooses. It sends it out an invalid hardware output instead of the bus sends..
Here's a screen shot of what happens (see snr + clp tracks):
http://imgur.com/Da97a
Sometimes, when it works, it would set their outputs through a bus, but instead it sends them out inactive hardware outputs. Not fun...
Old 07-07-2012, 09:55 PM
Please, anyone? I can't believe other people aren't having this problem - this really kills my workflow!
Old 07-08-2012, 09:06 AM
Tweakhead Tweakhead is offline
I/O Setup / Bus / Default Output Bus
Set your preferred path.
OK.
Old 07-08-2012, 09:17 AM
WernerF WernerF is offline
I don't know if the "set default output track reverting back to 1-2 everytime you reopen the session" has been fixed or not but the trick of setting the default output track and then moving it to the top of the IO list does work to keep it from resetting when you reopen the session.
Old 07-08-2012, 06:57 PM
Thanks for helping guys, but this isn't solving my problem. I am not talking about a default output when you create a new track from "shift+cmd+n" or from the drop down menu - I am talking about default output when creating a new track from the "SENDS" menu. Changing I/O settings doesn't affect this..
Old 07-08-2012, 08:08 PM
flommer flommer is offline
It appears to be working correctly for me. According to the reference guide it should only be a bus, not a hdwr insert.
Also, your screenshot makes it look like you were using "New track" from the outputs selector, not the sends selector? Or did you make the track then delete the send? I can't seem to make multiple assignments at the same time so I am assuming that you are manually assigning these outputs like that. If so then I don't really see how much time the "new track" feature is saving you, perhaps there is a better/similar way. Maybe just make your new Aux first, then it will be available in the sends>track> list (or track outputs, whatever you are actually doing)
I would suggest updating your Protools to 10.2, perhaps that will clear out a bugged preference..
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R
Old 07-09-2012, 03:12 AM
weezul weezul is offline
I've been having this problem too. Makes bouncing stems take just that little longer... not fun.
I've also been having another problem. I make a template, and create two sends, 3-4 for verb and 5-6 for delay. After opening another session which used the same template, and then going back to the other, all the sends get made 3-4, so i end up with two 3-4 sends on each track, and I have to reroute all the delay ones to the right send. This is very frustrating and I don't see why this would happen, it happens whether "Sessions overwrite I/o" is on or off :/
anyone else having this problem?
MacBook Pro: 16GB M1 Pro 8c
Hackintosh: MacOS Catalina, i7 6700k, 32GB RAM, RX580
Pro Tools Studio, RME RayDAT PCIe
http://www.liamgaughan.com
Create and Assign New Track from Track ZEROPRO Windows 2 12-05-2011 09:15 PM
Create New Track in Track Output ZEROPRO Pro Tools M-Powered (Win) 0 12-01-2011 02:01 PM
Interesting anomaly: Output>New Track>Audio Track result EuropaStudiosInc Pro Tools TDM Systems (Mac) 0 01-24-2011 02:57 PM
Track offset menu or track freeze as workaround for ADC? mixaudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 10-27-2008 12:19 PM
