Re: Protools HD8, spdif FW saffire le.
Thanks djmj,
To confirm, you are only using the Saffire LE for the Windows Sounds, as PT HD8 would only be using it's own cards, is this correct? Are you able to run Windows Sounds normally through the Saffire LE with Pro Tools closed? Are you able to test the Saffire LE in another DAW like Reaper? Best regards.
Katherine Kaplan // Focusrite Technical Support http://www.focusrite.com/answerbase/en/ |
My System spec.
I have two Digidesign 192, HD4 pci cards. One core and three accel cards.
I have 1600mhz memory, sata3 hd and i7 cpu LGA 1155. System spec: Windows: Windows Version 6.2 (Build 9200) Internet Explorer: 9.10.9200.16921 Memory (RAM): 8141 MB CPU Info: Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz CPU Speed: 3568.1 MHz Sound Card: SaffireLE Output 1/2 (Focusrite | SaffireLE Output 3/4 (Focusrite | SaffireLE SPDIF Output (Focusri | SaffireLE Output 5/6 (Focusrite | Display Adapters: AMD Radeon R7 200 Series | AMD Radeon R7 200 Series | AMD Radeon R7 200 Series | AMD Radeon R7 200 Series | AMD Radeon R7 200 Series | AMD Radeon R7 200 Series Monitors: 2x; BenQ G2450 (Digital) | BenQ G2450 (Digital) | Screen Resolution: 1920 X 1080 - 32 bit Network: Network Present Network Adapters: TP-LINK N600 Wireless Dual Band USB Adapter CD / DVD Drives: 1x (G: | ) G: Optiarc DVD RW AD-5280S Ports: COM1 LPT1 Mouse: 5 Button Wheel Mouse Present Hard Disks: C: 1862.7GB | D: 298.1GB | E: 465.8GB Hard Disks - Free: C: 1809.0GB | D: 298.0GB | E: 313.5GB USB Controllers: 3 host controllers. Firewire (1394): 1 host controllers. Manufacturer *: American Megatrends Inc. Product Make *: To be filled by O.E.M. AC Power Status: OnLine BIOS Info: AT/AT COMPATIBLE | 08/21/12 | ALASKA - 1072009 Time Zone: W. Europe Standard Time Battery Status: No Battery Motherboard *: Gigabyte Technology Co., Ltd. P75-D3 IP Address: 192.168.1.1 | MAC Address: 10-FE-ED-21-9E-4E Host Name: PROTOOLSHD SM BIOS: F9 |
Saffire Pro 40, ADAT & SPDIF? | dr_daw | Third Party Interfaces | 5 | 10-14-2014 08:17 PM |
PT 10 & Focusrite Saffire Pro 40 & tc elec. M-One XL SPDIF Problem | mistamarc | macOS | 1 | 04-09-2014 06:31 AM |
Using Focusrite Saffire Pro 24 with Protools 10.3.5 | aussie45 | macOS | 6 | 06-25-2013 05:42 PM |
Protools 10 with Saffire Pro 40 | navneethbalachanderan | Windows | 3 | 12-29-2011 07:40 PM |
Please Help Me...Focusrite Liquid Saffire 56 i/o with protools 7.4 LE | Shocktone | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-28-2011 06:37 PM |
