Old 03-10-2009, 01:57 PM
innerbooty innerbooty is offline
Default Fades corrupted when copying session from drive to drive?
I'm working on a session today was saved down from Pro Tools 7.4 to 6.x so I could mix and edit on my Mix system. The session saved down fine and I opened it up in Pro Tools 6.4. There are over 1,000 fades. They all sounded good. Then I made a copy of the whole session, data and fade files to another of my drives to do the work. When I opened up the session over there I got the usual "disk allocation" messages, and the Task window to locate the audio and fade files, which I set to "automatic". It found them all no problem. But when I started working in the session I got suspicious because every fade sounded like crap, with pops and clicks that should not have been there. If I deleted out the crossfade and rebuilt it with Ctrl-F in exactly the same spot it sounded fine. So something about opening up the session and locating the fades on the new drive totally screwed them all up. I tried setting up the session again this time clicking on the "regenerate fades" box, but it didn't make any difference. The session is configured as .WAV, and I'm running a G4 Tower / OS 10.3.9. Would that be it...?
If I do a "Save Session Copy In..." from the first drive to the second, and choose to create a copy of all the audio files and fade files, that works fine...
Shouldn't I be able to just copy everything to another drive, open the session and have it find all the fade files - and have them not be messed up...?
Thanks! - Steve
Old 03-10-2009, 07:03 PM
BaileyBass BaileyBass is offline
Default Re: Fades corrupted when copying session from drive to drive?
Originally Posted by innerbooty View Post
Thanks! - Steve
how are you copying? If "Save Copy in" works, use that. I have often heard (but have no evidence) that "drag copying" sessions can be a problem. Not always, but occasionally. There may be an issue with your PT version; do a search or look in the support link above. SB
Old 03-10-2009, 10:08 PM
the dude's Avatar
the dude the dude is offline
why even bother copying any fade files ?
just skip all the fades and re-calculate them when you open the session
http://www.studio-techservices.com
าำ
studio.tech@yahoo.comm
Mitch Berger Tech Services
We service ALL Avid products no Problem
HD192, 192, Omni, Control Surface, Pre, XMON, 192HD AD & DA / Accel Cards, Everything
ALL NEW HD192 AD -DA modification. the difference is incredible... no need to ship the entire unit , fast turn around
inquiry using link above
Repairs of SSL-Neve- Consoles and Repair ALL Modern & Vintage Gear
Old 03-10-2009, 10:13 PM
audiogeekzine audiogeekzine is offline
+1 forget the fades.
@theaudiogeek
| www.EPICSounds.ca | www.AudioGeekZine.com | www.HomeRecordingShow.com |
problems after copying session to new hard drive anklebiter 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 09-22-2009 10:10 PM
Disc Allocation when transferring session from drive to drive... Roy Howell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 03-17-2003 04:37 PM
external drive was corrupt...lost 4 sessions after copying them to drive. help! djc8902 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-12-2003 02:27 PM
corrupted audio suite files/drive stratosphere Pro Tools TDM Systems (Mac) 0 03-04-2002 05:49 PM
copying a session to a new drive... maatmu Pro Tools TDM Systems (Mac) 10 08-30-2000 08:16 PM
