Upgrading Eleven Rack
Hello everyone,
I'm new to this forum and purchased an Eleven Rack with Pro Tools LE back I believe in 2010. I went to NAMM ( I work at a music store ) got a good deal through where I work but never had time to use it. So I have been messing around with and want to start diving in. So on to the questions/ statements and here is what I am looking to do. Q1 -Is it possible to upgrade an older Eleven Rack ( I believe I have version 1.0.2 ) to the latest version with the expansion pack? Q2 - I have Pro Tools LE ( I think version 7 ) running on an out dated Dell XP machine. Would it be possible to install the same software on a newer windows machine (Windows 7) as I have all the original install CDs? Any info / advice would be greatly appreciated. Thanks ! Jim |
Re: Upgrading Eleven Rack
The Eleven Rack hardware hasn't changed, so yes you can update to the expansion pack.
You could probably install Pro Tools 7 on a new system, but it's outdated to the point that I wouldn't even bother. Just download the standalone Eleven Rack editor if you want to edit presets on your computer |
Many of the original ProTools LE disks did not work and you had to download from Avid, if I recall.
[SIZE="2"][COLOR="Blue"]Intel Haswell-E Processors 3.3GHz Core i7-5820K 6-Core; Memory - DDR4: 16GB DDR4-2400 Quad Channel (4 x 4GB); Primary Drive (OS): 240GB SSD SATA3; Secondary Drive (Audio): 2TB 7200 rpm SATA2; Graphic Card: 1GB (HD5450) Dual Display Graphics Card; Optical Drive: 22x CD/DVD Dual Layer Burner; Windows 10 64-bit; PT 12.5; Studio One Pro 3.2; Cubase Pro 8.5; REAPER; MixBus 3 |
Thank you for the info....
I am assuming then I can update the firmware before I get the expansion pack? Thanks ! |
How and Where can I upgrade the firmware ?
Sorry for the tons of questions....I'm looking to get a new Pro Tools System, but I want to be as cost effective as possible.
So my question is how and where do I upgrade to the latest version firmware for the 11 Rack ( I purchased mine in 2010 )? From what answers I have received from my previous post, none of the hardware has changed since the 11rack has been out so doing a firmware update is possible? Thanks ! |
Huh? The Expansion pack is a firmware update. Firmware 2.x is the expansion pack.
Re: How and Where can I upgrade the firmware ?
You only get version 2.x firmware if you purchase the expansion pack. |
Ok thanks... just found that out. I didn't realize the expansion pack was the firmware update as well.
Thanks! |
I just realized that they were both....expansion was also the new firmware.
Thanks ! |
Check out the Eleven Rack Presets Matched for Eleven plugins by Pro Tools Expert! | Justin1524 | Eleven Rack | 0 | 11-27-2015 02:53 PM |
Eleven Rack / Avid is not producing anymore Eleven Racks is that true or false? | Rongpat | Eleven Rack | 8 | 02-11-2014 07:42 AM |
Eleven Rack window responds to changes on Eleven Rack, unable to record. | pine | Eleven Rack | 6 | 08-02-2012 07:50 PM |
Eleven Rack and Eleven Rack control window not matching | 11R Newbie | Eleven Rack | 3 | 04-18-2012 06:07 PM |
"Eleven Rack" window gone in PTLE after upgrading to Lion? | Deny | Eleven Rack | 6 | 10-03-2011 07:23 PM |
