Old 09-30-2022, 09:02 PM
Bucky Bucky is offline
Default Behringer X-Touch
Hello I have a Behringer X-touch one that is daisy chained to an X-Touch Extender. They are able to communicate with Pro-Tools but the issue that I am having is that when the devices pull the track info, the first 8 channels will go to the X-touch one and the X0tender will pick up tracks 9+. Is there a way to get it where the extender picks up on track 2 and not track 9. And when I say tracks 1 or tracks 9 I am talking about the order they are listed from top to bottom in the mix window. Thanks in advance.
Old 09-30-2022, 10:17 PM
smurfyou smurfyou is offline
Default Re: Behringer X-Touch
HUI wants to bank in 8 channel increments. I'm not sure you can do what you want. Is the Extender meant to work with the Xtouch One or just the regular Xtouch?
~Will
Old 10-15-2022, 04:48 PM
This^^^ is also what I would expect. But having said that; its easy to make changes to the settings, so you can try changing the X-Touch One to 1 instead of 8(not sure what will happen, but its easy to test). If that doesn't work, try disconnecting the X-Touch One and setup only the 8-fader unit and see if that works by itself. As smurfyou says, the extender might not work in this configuration(IOW, it may require the full-sized X-Touch instead of the "One")
Behringer X-Touch Faders djohnson223 Third Party Interfaces 11 01-13-2022 09:30 AM
Behringer X-touch issue secret studios Pro Tools 12 4 10-23-2021 04:38 AM
Behringer X-Touch or Presonus Faderport 8 or ..? JBQIII Pro Tools 12 11 08-20-2017 07:28 PM
FS Behringer X-Touch brianjanthony Buy & Sell 0 05-26-2017 05:42 AM
Behringer X-Touch peter5992 Third Party Interfaces 1 02-04-2015 09:56 PM
