Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | MTRX & MTRX Studio
Old 10-13-2019, 07:40 PM
SomeOtherGuy SomeOtherGuy is offline
Default How to go from Apple TV digital out to MTRX?
I want to extract digital audio from an Apple TV 4th Gen with a HDMI + HDMI Audio extractor box. This extracts an Optical output from the HDMI signal. This then goes to a HOSA Optical to AES/EBU converter box. And from here it goes to the Avid MTRX AES-in.
This doesn't work because the extractor doesn't have a Optical IN for clocking. The result is the audio plays but drops out every few seconds.
No HDMI audio extractor I've found have an Optical IN, only OUTPUT.
Is there a better way to do this? I need all my MTRX analog inputs otherwise I just use them.
Pro Tools Ultimate, Avid MTRX, MOM, MacBook Pro 16 (2023) 96 GB RAM, Mac OS Ventura, Samsung SSDs
Old 10-13-2019, 07:52 PM
lucienpalmer lucienpalmer is offline
Default Re: How to go from Apple TV digital out to MTRX?
So you are trying to record the audio signal?
Usually the output from the Apple TV is a Dolby encoded output. Are you tying to record a simple stereo, 5.1, or Atmos?
Pro Tools Ultimate, HDX3 & MTRX + HD MADI
7,1 MacPro, 3.2GHz 16-core, OSX 10.15
S6 M40 48-5, panners, MPM,Dolby Atmos RMU
AJA Kona LHi, Sync HD
www.ToolshedAudioPost.com
www.TheToolshedStudio.com
Certified for Dolby Atmos Home Entertainment
Old 10-13-2019, 07:54 PM
Just want Apple TV playback, no recording. And just stereo...
Old 10-13-2019, 08:28 PM
If clocking is the only issue change you Pro Tools/MTRX setup to clock from its AES/EBU input.
Old 10-13-2019, 08:34 PM
Thanks, I just tried that but get a SYNC Loss alert and the audio still drops out every 5 seconds or thereabouts...
Old 10-13-2019, 08:37 PM
Then you likely have other problems in the conversion chain than just clocking. Can you try swapping components/cables. Can you run TOSLINK into the AES/EBU converter say from a CD player or a Mac with optical out to test that works. Is it an old Apple TV with TOSLINK out that you can go directly into the TOSLINK Adapter?
Old 10-13-2019, 08:43 PM
It's a 4th Gen Apple TV so have to use an HDMI + HDMI Audio extractor box. This has a Optical out only. I did swap cables. I generally find that whatever I hook up using the AES inputs on the MTRX, I need both IN and OUT connected. For example, I have a HAKEN Continuum controller hooked up via AES, but I get dropouts or it won't work at all unless it's connected to both AES In and Out.
Old 10-13-2019, 09:28 PM
Any chance you have a Dante card on your MTRX? I use these adapters to get as much audio input as I need....
https://www.amazon.com/Audinate-Dant...C4Y?th=1&psc=1
I know it doesn’t directly solve your problem, but thought I would mention that Incase the sync issue doesn’t work out.
Old 10-13-2019, 09:43 PM
Thanks for that, looks interesting. I'd get a Dante card if it's solve this clocking issue, since I'd to stay digital if possible. But you're saying with this I could go analog into the Dante card. That might be the way to go...
Old 10-13-2019, 09:50 PM
Not sure going Dante to just get analog would make sense.
Do you have something like an RME ADI-192 DD you can borrow? That gets you SRC (pretty sure it regens off the input clock at the same sample rate) tied to a clock signal. Super handy boxes, but overkill in general for this... but if you can borrow one.
Are other MTRX as touchy for locking to AES/EBU? I'm more guessing your Apple TV may be running a little loose. But if it happens with other stuff...
What computer do you have? Does it have optical in? (I'm guessing from your info you mean a late 2013 trashcan, so no). Maybe consider buying a USB or thunderbolt interface with optical in and switch to Pro Tools Standard while importing that S/PDIF input.
HD I/O with MTRX Artis Pro Tools | MTRX & MTRX Studio 10 07-04-2019 10:01 AM
MTRX and S6 quadraphonics Avid S4/S6 18 08-21-2018 06:12 PM
MTRX Box JSR Avid S4/S6 4 11-01-2017 12:46 PM
MTRX antonis Post - Surround - Video 2 10-26-2016 12:31 AM
Anyone been able to get 2 Apple digital monitors working? EthanMorse Pro Tools TDM Systems (Mac) 0 11-06-2001 10:02 AM
