Old 03-03-2023, 08:23 PM
aftermid aftermid is offline
Default nanoKontrol 2 Midi CC Controller
I've been trying to use the nano for Pro Tools. When you set the peripherals in Pro Tools to HUI, it works as great control surface. But if you put the nano in Midi CC control mode for using it to control expression, modulation, etc. the transport controls on the nano are inactive. I'd like to be in Midi CC mode with the advantage of still being able to use the transport controls.
Pro Tools lists the Midi CC#'s for stop, play, and rec respectfully as 119, 117, 118. I assigned these numbers to the nano, but the transport buttons won't work.
Does anyone know how I can be in the Midi CC mode in the nano and still keep the transport functions, without have to go back and forth between control surface mode and midi mode on the nano?
Old 03-03-2023, 10:51 PM
smurfyou smurfyou is offline
Default Re: nanoKontrol 2 Midi CC Controller
I don't know if it will work in your situation but check this out:
https://www.refusesoftware.com/mulligan
~Will
Old 03-05-2023, 10:47 AM
Thanks,
I checked out their site. I probably contact them and see, if I can use it simultaneusly as a tranport controller and midi CC. Their video focuses more on using it to control plug ins. We'll see, thanks for the tip.
Korg nanoKontrol 2 aftermid Pro Tools 2020 0 02-28-2023 07:18 PM
Korg Nanokontrol 2 Olly2000 macOS 2 11-11-2014 06:13 AM
Korg NanoKontrol in PT MP9? jglunt2112 Windows 5 01-20-2014 10:11 AM
Korg NanoKontrol & PT LE lionelcollins MIDI 91 10-06-2012 01:57 PM
help me test a nanokontrol app eesn MIDI 3 03-14-2011 07:58 AM
