Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 02-28-2023, 07:18 PM
aftermid aftermid is offline
Default Korg nanoKontrol 2
I've been trying to use the nano for Pro Tools. When you set the peripherals in Pro Tools to HUI, it works as great control surface. But if you put the nano in Midi CC control mode for using it to control expression, modulation, etc. the transport controls on the nano are inactive. I'd like to be in Midi CC mode with the advantage of still being able to use the transport controls.
Pro Tools lists the Midi CC#'s for stop, play, and rec respectfully as 119, 117, 118. I assigned these numbers to the nano, but the transport buttons won't work.
Does anyone know how I can be in the Midi CC mode in the nano and still keep the transport functions, without have to go back and forth between control surface mode and midi mode on the nano?
Korg Nanokontrol 2 Olly2000 macOS 2 11-11-2014 06:13 AM
Korg NanoKontrol in PT MP9? jglunt2112 Windows 5 01-20-2014 10:11 AM
Korg NanoKontrol in PT MP9? jglunt2112 Pro Tools M-Powered (Win) 0 01-02-2014 08:23 AM
Korg NanoKontrol & PT LE lionelcollins MIDI 91 10-06-2012 01:57 PM
Korg nanokontrol 2 with pT 10 Peter Groom Windows 1 08-15-2012 01:45 AM
