Old 12-26-2016, 08:17 AM
justus1900 justus1900 is offline
Default Pro Tools 12.7 separate clip?
Pro Tools 12.7 separate clip? I'M trying to separate a clip so I can Cut and Paste in another spot and in Pro Tools right click Separate in the dropdown is Grayed out and doesn't work. Is there now some special way I need to work to separate a clip? Thank you
Producer/Engineer/Musician
RIAA Platinum Sales Award: Lisa Stansfield "Affection"
Main:
Model: Dell 5750 Precision Workstation
OS: Windows 11 Pro 64bit
CPU:*Intel Core Processor i7-10750H (6 Core, 12MB Cache, 2.60 GHz to 5.00 GHz,
Memory:64GB, 2X32GB,DDR4 2933Mhz Non-ECC
OS M.2 512GB PCIe NVMe, Record Intel 1TB SSD, 2T SSD, 1TB SSD
Focusrite Scarlett 18i20 3rd Gen
AVID Pro Tools 2023.12
JBL LSR4328P 8"
JBL LSR310S 10 inch Powered Studio Subwoofer*
Yamaha HS50M Studio Monitors
Alesis Elevate 3 Studio Monitors
M-Audio Axiom 61 Midi Controller
Old 12-26-2016, 08:45 AM
amagras amagras is offline
Default Re: Pro Tools 12.7 separate clip?
Nope, you might have to check if your track is frozen, committed or locked in some other way, also, try the key command for that which is B
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
Old 12-26-2016, 08:56 AM
Key Command worked... I have a Pro Tools Key Command Keyboard and didn't even think about that? But Thank you..
PS: The Track wasn't frozen, committed or locked in anyway. I keep getting a couple of "AAE 6 Errors" on some old sessions, I think I might uninstall and reinstall Pro Tools and see what happens.
Main:
JBL LSR4328P 8"
Old 12-26-2016, 02:49 PM
rossi68 rossi68 is offline
I never understood why they removed the right-click option... Makes no sense...
Antelope Orion Studio 2017, UA 4-710, Presonus digimax FS, Sony DMX r100
Old 02-21-2017, 10:27 PM
LA-3A LA-3A is offline
So I upgraded recently to 12.7 (run Mac OS 10.12.3) and have the same issue. Right click and Separate is greyed out of the drop down.
Has there ever been a definitive answer to this issue?
Bummed... that it's really messing with my work flow.
Old 02-22-2017, 02:13 AM
melloj melloj is offline
You do realise that you can select an area and copy/paste without having to cut the Clip? 99% of us use the B short cut and the other 00.5% use Ctrl-E. If it's been removed from the drop down menu it's because it's of little use to most users.
Old 02-22-2017, 03:05 AM
midnightrambler midnightrambler is offline
99% of statistics are made up.
If it's been removed from the drop down menu it's because it's of little use to most users..
It hasn't. http://duc.avid.com/attachment.php?a...1&d=1487761531
Old 02-22-2017, 08:36 AM
Click image for larger version
I am talking about RIGHT CLICK on a WAVE FORM.... SEPARATE is still there, but greyed out.
I know the keyboard short cuts and the drop down MENU BAR options. But this is the menu the appears when you RIGHT CLICK on a WAVE FORM.
Slowing Down Of Separate Clip.... The Weed Pro Tools 12 9 08-22-2019 04:49 PM
PT crashing when creating separate clip manyrains Pro Tools 12 0 11-25-2016 10:33 AM
Batch separate clip at memory locations exist for Post workflows? evil_cliff Pro Tools 12 6 06-15-2016 12:27 AM
Separate clip/region with a group of drum tracks has a 2-3 second latency. broken81 Pro Tools 10 4 03-17-2014 05:55 PM
Finally separate clip muting available :-) mrpollack Windows 5 10-27-2011 08:24 AM
