#121
Re: Let's have a count up who's getting the freeze problem!
Count me in. It's killing my studio business. I upgraded from 8 no major problems to 10 a deathblow. Frezzes when it likes. I found if I play through it a few times it is less likely to freeze. Maybe if I knew where it plays from (ie: Ram? HD? Pagefile?) I could help distribute load. Even tried Stoping Services. The Error: "Overload CPU, check compatible disk drivers, remove native plugins, increase H/W buffer, thin automation" Accept for a new CPU evrything has been updated, maxed and set as best I can. Not sure about native plug ins however (never installed plug ins). I monitor with win 7 system meters, the cores and Hard Drives, and with PT usage meters. PT meters show: PCI 40%, Cpu 1%, CPU Clip 0%, Time slots 32/512, HD engine 100% Red Lined???(Not sure about this one?), Sound mixer 75%, Dverb 25%. Nothing even at the freeze moment spikes or gives me a clue. I am using P6T Asus, i7 920 2.66G overclocked to 3.1G continuous run (Stable with many other prog running, tested with taxing SW.), ram TR3x6G 4 gig, 2 Seagate 1T 32M SATA ST31005N1A1AS (no windows file compression), Video GeForce 9800GT Nvidia. Anybody have optimizations I missed?
#122
Here are the recommended optimizations. Before I would allow this to 'ruin' my studio business, I would temporarily go back to my last system image.
#123
Raoul Crane
www.blaze-studios.co.uk PT 10.3.10 HD Accel 6, Mac Pro 5.1 12 Core 3.46hz Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis |
#124
Also as annoying as it is, reinstalling windows fresh and reinstalling everything new can make a world of difference. It's the only way I will roll!!
pro-tools-pc.com TRASHER Pro Tools Utility(updated 4-11-2024) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 |
#125
PT8HD on XP worked fine, to PT10 on Win7 everything works but freezes with an error message. There is no turning back to the last system image. I never thought about the IRQs however. Thanks for the link to Win7 Optimization Guides. I found a couple of things I needed to know that may be the ticket.
I still have the 003 rack with PT8 on a WinXP computer that is working. I will let you all know what was the cure. |
#126
Also, be sure you are installing PT10.2. This version has a fix for the freeze issue that some were having.
#127
No I havent. Ive never had to before I wasnt aware of this. Did I find it. I went to device manager and I see Network Adapters under this I see only one it says Realteck PCIe GBE family controller. So do I have to always keep this disabled? And by disabling this am I causing something else in my computer I need to not work? Ok I just disable this launched PT 10.2. I still have same problem. Ilok tells me to abort.. Raoul I just noticed you said in your case Ilok is kmissing. Mine is not missing. Ilok tellls me to update my ilok driver. Which Ive done repeatedly... Thank you |
#128
Raoul Crane
#129
No I have not done a fresh OS install. I have to done a clean install of PT 10.2. This is so strange. I can open PT 10.2 and use it. Its just everytime I launch it, a warning window keeps popping up telling me to abort and update my ilok which Ive done repeatedly. Then Ill get a clip board saying I cant use about 8 AXX plugins. Ive been a PT user since 2007. Ive NEVER had any ILOK issues til PT 10.2. |
#130
So pro tools works ok it just shows up this message everytime. As for the AAX plugs I've never thought about these as I just use RTAS and TDM. I would do a system image then do a clean install of OS and pro tools if it still happens you can revert back to your image
Raoul Crane
Unusual Count-Off Problem | mkorch | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 03-20-2012 07:39 AM |
click pre count problem? | bluebearddub | Pro Tools M-Powered (Win) | 3 | 06-20-2009 04:05 AM |
Problem with count-in | funkosauras | Pro Tools M-Powered (Mac) | 0 | 04-02-2008 04:17 PM |
High track count errors, Sync i/o problem? | IndreStudios | Pro Tools TDM Systems (Mac) | 7 | 03-26-2008 07:07 AM |
Count in Problem | Brahmb | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 08-09-2000 07:10 AM |
