Hardware EQ insert works, but commit records no audio
Hi folks,
I am running a Motu 828es interface with a Neve 1073N prramp/EQ unit. I recorded a vocal track dry with no EQ and am now trying to use the outboard EQ on the Neve unit to mix. I have set it up properly (I think) going out and in the same channel on my interface to the Neve. I can confirm I'm hearing the EQ process on the audio track where I put the hardware insert. Once I've got it EQed how I want I right click the track and hit commit. The track plays and a new audio track is created right below it, but there's no audio data in it! I'm totally confused about what I could be missing here. Any help is much appreciated! |
Re: Hardware EQ insert works, but commit records no audio
offthewallproductions Mac Pro 5,1 3.46 Ghz 12 core, Open Core 0.9.8, Radeon RX580 GPU, GC-TITAN RIDGE TB3 PCIe card, M.2 NVMe SSD boot drive on PCIe card, 48GB RAM, macOS 12.7.4 Pro Tools Ultimate 2024.3.1/HD Driver 2023.3 HDX, UA Octo PCIe card in external TB3 chassis, MTRX Studio I/O, C|24 control surface. Genelec 1031AP/7070A 5.1 monitoring. |
Try right clicking on the tab where the Neve is and select commit up to this insert. Does that work??? It should.
Steve
Steve Shepherd Extreme Mixing |
Ugh I totally thought that was the thing I was missing (I had been right clicking on the whole track) but sadly it made no difference. Still no audio copying to the new track.
I have no idea. Maybe it only works with Avid Hardware. That's what I'm using. HD Native with an Omni interface and a 192. You may have to just record to a new track. Hardware commits are real time anyway, so it's not so bad.
Stteve
Hmm the hardware shouldn't matter since PT can't actually tell what it is - it can only see the interface I'm using. What I don't get is that I can HEAR the EQ when I insert the send. I must have the I/O or something co figured incorrectly. Hoping someone from Avid can chime in and let me knownif this is a known issue.
Is this where I set the output of the track with the hardware insert as the new track, then the input of the new track the output is the one with the hardware insert? Example: Vocals A [Hardware insert] Output set to Vocals B Vocals B Input set to Vocals A Record arm Vocals B and hit play? |
Do you have LLM switched on?
(just a thought -- don't know how Motu's mixer software works)
When PT is acting weird I usually delete preferences and restart computer.
Mac Mini M1 | Mac OS 12.6.1 Monterey | Avid Carbon + 2x Carbon Pre | Pro Tools Studio 2024.3 |
Commit up to this insert... | m4tune | Pro Tools 2020 | 8 | 10-21-2020 02:18 PM |
No audio w/Hardware I/O Insert | lctofu | Pro Tools 2018 | 8 | 04-15-2019 10:16 PM |
Commit up to this insert | michael c | Pro Tools 12 | 8 | 07-27-2018 08:31 AM |
Commit up through this insert? | Carl Lie | Pro Tools 12 | 7 | 01-24-2016 10:23 PM |
unable to locate m-audio hardware. make sure your hardware is..works fine in ableton? | pein | Pro Tools M-Powered (Win) | 2 | 10-07-2009 12:01 AM |
