Old 10-23-2020, 06:03 PM
bsteeve bsteeve is offline
Default PT Shortcut for cascading outputs no working anymore in PT 2020.9.1 master faders
This is really bothering me...
shift + control + command modifier does not allow me to cascade my output on my master faders going to the DAPS... it works on audio tracks and auxes but not on master faders... what is going on? it use to work in the past
Old 10-23-2020, 08:15 PM
LDS LDS is offline
Default Re: PT Shortcut for cascading outputs no working anymore in PT 2020.9.1 master faders
I never got it to work in 2020.5 either. Every other type of channel seemed find... just no luck with master faders.
Old 10-26-2020, 12:11 PM
Ryan Young's Avatar
Ryan Young Ryan Young is offline
I think for it to work properly, each of the cascading outputs have to be the exact correct channel width and in the same order as your master faders. You can rearrange the order in your io window if needed, then try it again.
-Ryan Young
•2019 Mac Pro 3.5 GHz 8-Core Intel Xeon W - 48 GB 2666 MHz DDR4 (OS 10.15.5) •HD Native PCIe, HD Omni, 192 I/o, Pro Tools Ultimate •Avid S3 + Dock •Blackmagic Intensity Pro (HDMI) •5.1 Room with JBL LSR4300 series
Additional Systems
•2010 Mac Pro 2 x 2.66 GHz 6-Core Intel Xeon - 48 GB 1333 MHz DDR3 (OS 10.14.6) •HD Native PCIe, 192 I/o, 96 I/o, Pro Tools Ultimate •McMix (x4), McControl (x1), JLCooper Surround panner for D-Command ES, Avid Control •Blackmagic Intensity Pro (HDMI) •7.1.4 Room with JBL LSR4300 series
•2017 MacBook Pro 2.8 GHz i7 - 16 GB 2133 MHz LPDDR3 (OS 10.14.6) •HD Native TB, HD Omni, Pro Tools Ultimate •McMix (x1), McControl (x1), Avid Control * or * D-Command ES Main Unit •Fed into whichever system is the main system
HTML code is On
Not possible to use a Eucon workstation as Slave OR Master anymore ? Uli Auer Artist Series 3 05-17-2019 02:17 PM
Can't acces outputs anymore!! usastra Pro Tools TDM Systems (Win) 3 08-11-2008 03:24 PM
Shortcut doesn't erase notes anymore after upgrade musicalavtech 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-05-2007 02:03 AM
001 midi inputs/outputs dont work anymore? El CaCa 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-10-2004 09:19 PM
Cascading direct outputs in mixer? D Pinder Tips & Tricks 5 03-17-2000 03:41 PM
