peak meters
I should like to know why the peak meters on the single track do not go over the 0.0 even I push the slider at maximum. What can I do to see the peak meter +6.0 as written on the reference guide?
Re: peak meters
The peak meters are called PFL meters (for pre fader listen, like the professional mixers). It show only the level of the track recorded. If you push the slider at maximum, you send to the group or mix +6dB but you see only the level of the recorded track (without the amplification of the slider). For see the amplifier level, you can create a master track or bus track and the peak meters of this track show the level with the amplification.
Sorry for my english...... ------------------ Arnaud Ruffieux / Ruff-Tang Prod. |
Re: peak meters
Thank you. But I referred to the master track and even the peak meters are constantly red with slider at maximum, the number that appears on the track does not go over 0.0 dB. I do not know why. It is like there is a compressor anywhere. Maybe I have to change some preference? Thank you.
Meters won't peak while recording...EVER!!?!?? | illution1 | Pro Tools 10 | 39 | 04-29-2014 10:21 AM |
Peak meters accurate?? | mushmouth | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 05-05-2006 09:21 AM |
Meters--Peak or PPM? | danika | Pro Tools M-Powered (Win) | 0 | 10-15-2005 12:55 PM |
Meters Peak Hold???????? | tnie | Pro Tools TDM Systems (Mac) | 9 | 05-31-2003 12:47 AM |
Outboard VU/Peak meters ... | CCash | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 12-04-2002 04:12 AM |
