Protools 6.0 Wishlist...
So before it comes out, what's everyone want? hat way they can make sure not to give it to us, and taunt us later with patches [img]images/icons/smile.gif[/img]
I want: Patch Names ASIO Support Rewire support VST Support (Just for the Synths even!, I don't care about effects) 5.1 support (Give HD 7.1 support, so we are a little behind, and it doesn't screw sales) Dual Processor support (One processor for PT, one for Windows?)
---------------------------- David Fisher Berklee Student Boston, Mass |
Re: Protools 6.0 Wishlist...
Here's mine:
MIDI score editing (ie "notation") as an option instead of the "piano roll" metaphor. Give me this and I can forget about Logic nearly entirely. Importing mixer setups / layouts / snapshots. Having to start a new layout from scratch for a three song demo project sux. Come on Digidesign, any cheapo stand alone digital mixer can do this - why not PT? ASIO support. DX support. Yeah, it's not likely, but it would be nice... True 5.1 support. There's work arounds, but they're a hassle. It would be nice to have it in PT LE. DEFINITELY dual processor support! True, you wouldn't get double the performance, but even if it gave you a 30-40% increase, it would be worth it. One processor for PT, one for plug ins... TRUE dual monitor support. CALIBRATION MARKS on the meters!!! MORE I/O! Come on Digidesign - the Digi 002 looks cool, but can't you make an expansion option for it? Or let us run two of them at a time? I'd gladly buy two if I could use the controllers and I/O on both to control a single instance of the current 32 track PT LE software... It SUX that you actually have LESS I/O on the Digi 002 (at 96 KHz) than you do on the Digi 001.
Phil O'Keefe PT 2023.6 Ultimate (Perpetual) | Avid Carbon | M1 Max Mac Studio; 32 GB RAM / 1 TB SSD, macOS 13.4.1 Ventura. PT 2023.6 Studio (Perpetual) | M1 MacBook Air; 16 GB RAM / 1 TB SSD, macOS 13.4.1 Ventura. |
The annoying screen redraw problem that has been there since 5.01. When "show windows contents wile dragging" causes eraser-like marks in PT when the transport controller is dragged around.
Alex www.dreamware.ca Have something to brag about...Own a Dreamware Audio PC... My Rig: AMD Athlon XP 1700+ 512MB PC2700C2 Corsair MSI KT3ULTRA ARU 2x 80GB Seagate Barracuda 4 in RAID 0 GeForce 2 Ti 64MB Lite-On 40x12x40 CD-RW 16x Pioneer DVD Intel Pro/100 + SB Audigy Digi 001 |
Better Dual Monitor Support?
Tri-monitor support? (Matrox Parhelia) MIDI monitor of some type instead of just making a track. A tuner plugin built in? Could be helpful. I guess we have the signal generator.
-I would also definitively buy another 001 if I could hook them up together on the same machine.I am maby forgetting the obvious,but what is the best way to slave another puter with a 001 to another with the same?I dont mind if they keep the I/O limit to 16,because I will get to avoid the lightpipe and the expensive devices to use it with.
-more versatility with colouring tracks and devises...basically more manual control...so midi track 9 isnt light green while track ten is lightgreen minus two. -Right mouse button functionality.Specifically in the area of tool selection. -The ability to be able to import the track marker strip into another session. -Same as above with tempo,timesignature. -the ability to rename midi devices and channels. -the ability to make a track inactive,thereby freeing a track while keeping the original in the session but inaudible (like the use of "voices" in other apps. -the ability to save mutipleplug in combinations together...kinda like "rack sets" or something. -the ability to use stereo interleaves files as is and to edit them at least(for a last check up before burning) -an integrated spectrum analizer. -the ability to access basic information about a session,like for example session setup,tempo and session notes without having to open the session. -a simple and easy to use session clean up function.This will automatically compact and consolidate all regions that are audible,and save the clean session,or delete the files no longer used ,ready for backup.This is possible now,but a one stop function would be nice. -a shortcut for bounce to disk. -an output selector with shortcuts on masterfaders,voiding the need for a speaker selector box. -proper dual monitor support -a fit mixer to window function.
If you're gonna laugh about it later, you may as well laugh about it now |
Everything that David and Phil mentioned plus CD audio direct import, and an Instant bounce to disk option. That would be such a time saver!
COMMAND FOCUS MODE!!!!!!!!!!!!!!
That'de be good...
rh music |
I just want to use the wheel to move up and down or left and right or something like scrub or anything useful.
Please fix the S/PDIF optical so it stays set that way upon rebooting, instead of reverting back to ADAT.
Look into spontaneous reboots. The 001 is a factor in a lot of cases and this deserves to be fixed. |
ProTools User Wishlist / Shortcut for Selecting attached regions? | Arya44 | Tips & Tricks | 2 | 09-20-2009 06:48 AM |
Protools 7 Features WishList | Justin1524 | Pro Tools TDM Systems (Mac) | 186 | 08-31-2005 08:27 AM |
PT 6 Wishlist | Bodhiman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 10-14-2002 01:03 AM |
Xmas protools Wishlist:Click Plug-in | Rollerex | General Discussion | 2 | 12-24-2001 08:55 AM |
Wishlist for PT5.1 | iamstudios | Pro Tools TDM Systems (Mac) | 42 | 08-16-2000 12:36 AM |
