The Dock with the Artist Series
I never got a definitive answer on this question. Since the dock is supposed to work with Artist Series units as well as the S3, can you get features like VCA spill and global banking (ie: 4 mix units bank in blocks of 32 and/or track select from the dock instantly updates proximity on the Artist faders), or are you still limited to Artist features that will simply see the dock?
Re: The Dock with the Artist Series
As far as I know VCA spill is for s3 only although the dock should work with artist mix. PT control works fine with my artist mix.
I would be very happy to find out I was wrong and vca spill would be implemented with the artist mix units, but as far as I know it is an s3 only feature only. |
Right now I adjust plugins mostly on my Artist mix in flip fader mode as the rotary encoders are pretty bad. But adjust EQ/COMPS with faders is VERY accurate. Hopefully the Dock will have better knob encoders. I think someone mentioned that the knobs on the dock are taken directly from the S3. |
http://duc.avid.com/showthread.php?t=378357&page=2 The Dock and the Artist Control will not work together since Eucon sees those as two of the same type of units. Andy |
That is correct info, at the present time....
The Dock plus Artist Mix | KeyplayerG | Avid S1, S3, Dock and Control App | 17 | 03-05-2016 08:28 PM |
Pro Tools Dock confirmed to work with ARTIST MIX units. | bobbyguelz | Artist Series | 2 | 10-30-2015 12:23 PM |
Artist series with S5? | microRichardsLuvSUVs | System 5 | 3 | 07-22-2013 09:35 AM |
CSCooper MCS Series vs EU Artist Series? | GrievousAngel | Artist Series | 1 | 12-01-2010 01:10 PM |
