Re: Meters won't peak while recording...EVER!!?!??
That's right about the mix control, it's part of the driver for Focusrite interfaces. I did, however, just test this on my system (check my sig) and my meters clip on both the mix control and in PT. What version of PT? What version of Mix Control? Have you trashed prefs? What OS? Thought this would be a simple fix, have you checked the Help us help you - Read this before posting'? I've attached a pic of my system performing as expected.
FBR recording - https://www.facebook.com/fromthebase...cordsrecording @FBRrecording - Instagram Rig MBP 15" High Sierra 10.13.3, i7 2.6Ghz, 8Gb DDR, 750Gb 7200rpm, PT 2019.5, Focusrite Saffire Pro 40, Octopre MkII, Glyph GPT50, Avalon 737sp, AMS Neve 1073's, API 512c, CAPI 312's, DW drums, Fender Guitars/Amps, AKG, Rode, Sennheiser, Neumann U87 & KM184's, Coles 4038, Equator D5 monitors |
Disregard my last comment. I misread the thread that you suggested to me. DRE2580.
When reading it, I figured that it was talking about bypassing the Mix Control mixer in essence by directly routing a signal USING MC. I had no idea that you could actually get away with not even opening the program in the first place. In the past when attempting to run pro tools without the Mix Control, it would never ever work. In conclusion, loading pt without mix control at all worked like a charm and I no longer have the clipping display problem on the meters. Thanks dude! P.S. for other users who are experiencing this problem, make sure you set up all of your routing in mix control perfectly first (before you attempt to load pt without MC) |
Not sure if the upgrade of MC software is what fixed my (non) clip display issue or not, but I just realized that now I CAN see the clip indicator in both MC and PT mixer. (it also might have been my previous lack of experience and understanding of the MC router before I rerouted everything to my liking which caused the clip display problem however I don't really see how though) |
The mix control is a powerful tool, and can take a few months to get a handle on. In my setup (Mac) I never needed to open the MC, I just do for setting up my Headphone cues and ensuring that my hardware is connected prior to launching PT's. When I'm tracking, I do leave it open on the second monitor just to be sure I'm not clipping my A/D...nothing worse that a clipping that killer take! Katherine, from focusrite comes on here frequently and she is a great help. IF you have any issues with your setup you can always try to contact her via Focusrites support...or, I find the easiest way is through here :P Some days I miss Toronto because of the scene....then I look outside to my scenery Make music!
Glad u got it working....
#16
Thanks very much guys!
#17
OK, so I have another issue now. This maybe a very noob question but:
I was testing my location sound device's limiters and compressors (not recording into protools, but recording on a portable device) and then importing the files into protools. I was recording with the limiters off (to make it clip on purpose). I noticed that when I clipped the level on purpose and then imported that same file into pt, the audio track that the file is on will never show clipping in the meter. Shouldn't the pt meter clip when you import a file which has been clearly clipped during the recording phase? Heck, I even proceeded to recorde with my interface (while purposely clipping), exported that file to desktop, imported it again and played it with no clip indicator displaying in the pt mixer. I am so confused... |
#18
The waves will be cut at the top and bottom at 0dbfs, and become so-called square waves. A digital audio file cannot feed the PT mixer with anything more than 0dbfs, so it can technically not trigger the clip indicator, unless you boost it and meter post fader. You shouldn't worry so much. |
#19
Once set up to your liking (a process that took me 1/2 hour when I first installed my LS56), you NEVER have to actually launch MixControl - only if you have a need to change something. It's simply a router from the I/O to/from PTools. Think of it as a "digital patchbay"; once the "patchcords" are set, you can basically ignore it and get to work !!! It seems some people make a big deal about MC. For me at least, it's set-and-forget. (Well, you will need to open MC if you want to change your sample rate. For me though, this is a pretty rare occurence.) Hope this helps !!!
Desktop build: PT 2020.5 / Win 11 / i9-11900K @ 5.1GHz / 64GB / 4TB NVMe PCIe 4 / Gigabyte Z590 Vision D / PreSonus 2626 Laptop: PT 2020.5 / Win 11 / i5-12500H / 16GB / 1TB NVMe / Lenovo IdeaPad 5i Pro / U-PHORIA UMC1820 Ancient/Legacy (still works!): PT 5 & 6 / OS9 & OSX / Mac G4 / DIGI 001 Click for audio/video demo Click for resume |
#20
Peak meters accurate?? | mushmouth | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 05-05-2006 09:21 AM |
Meters--Peak or PPM? | danika | Pro Tools M-Powered (Win) | 0 | 10-15-2005 12:55 PM |
Meters Peak Hold???????? | tnie | Pro Tools TDM Systems (Mac) | 9 | 05-31-2003 12:47 AM |
Outboard VU/Peak meters ... | CCash | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 12-04-2002 04:12 AM |
peak meters | dellamattia | Digidesign Hardware & Software | 2 | 03-27-2001 01:35 AM |
