Old 11-24-2010, 03:06 PM
FluffyPost FluffyPost is offline
Default Timeshift: Conform 30fps to 29.97df fps pulldown is this correct??
having never performed a pull down before - how should i set up Timeshift so as to pulldown audio tracks created @ 30fps to 29.97fps
currently i am using settings:
'maintain pitch' > Film to NTSC -0.1%
Audio Mode > Polyphonic
Range > Wide
in doing this after the file is rendered it always finishes just short of the 29.97 video file i am conforming to - i can't even measure how short in samples but it requires a manual adjustment with the TCE tool
does this seem weird - should i manually conform the file with the TCE tool rather than use the 'Post format Conversion settings' that come with the plug?
Old 11-26-2010, 01:00 AM
Default Re: Timeshift: Conform 30fps to 29.97df fps pulldown is this correct??
anybody? .... pls ...
Old 11-26-2010, 01:47 AM
Use the vari-speed FIRST then the pitch correction. Otherwise you will have bad sync. See here
http://duc.avid.com/showpost.php?p=1496075&postcount=5
It´s about pal to film but the principle is the same.
frank.
Old 11-26-2010, 06:35 PM
thanks frank -will give it a burl
Old 11-27-2010, 09:56 PM
bluesfrequency bluesfrequency is offline
Actually you could just do a sample rate convert and maintain pitch while not getting any artifacting from TCE type plugins. Make a new session at 29.97, then import session data from your original session. Click on the SRC box and choose 47.952 from the pull down box (film to NTSC). Voila!
Carlos Sanches
Re-Recording Mixer
Audio Circus
Warner Bros. Animation
http://www.imdb.com/name/nm0760851/
Old 11-28-2010, 10:42 AM
Just a side note: SRC on import WILL change the pitch. It´s the equivalent to vari-speed (see the link I posted). It´s just that 0.1% of speed change is so low you won´t notice the difference.
Frank.
HTML code is On
nudge broken at 23.976 and 29.97DF or NDF Postman macOS 0 12-15-2011 03:28 PM
using 29.97 material going to 29.97DF digibeta Pabs Post - Surround - Video 3 08-07-2008 02:30 PM
30fps Reference JKD99 Post - Surround - Video 16 02-04-2005 04:46 PM
auto conform but no Post Conform Richard Fairbanks Post - Surround - Video 5 03-21-2004 10:35 AM
DV Capture@30FPS/PT Movie Pulldown Captain Audio Post - Surround - Video 10 07-31-2002 06:41 PM
