Old 10-05-2010, 04:11 PM
FluffyPost FluffyPost is offline
Default 5.1 Stem Limiter Recommendation and Thoughts
hi what are you guys using as 5.1 stem limiters
are you using limiters in multi mono mode or dedicate 5.1 mode
currently i'm using maxim or digi's comp/limiter in multi mono mode
i've looked @ the L2007 but it can't be channel linked on multi mono mode ... and there is no dedicated 5.1 version ... which is a bummer as i only hear good things about steve plugs
dsp efficiency as a consideration too?
any thoughts or experience shared is appreciated
cheers
Old 10-05-2010, 04:49 PM
EarHole EarHole is offline
Default Re: 5.1 Stem Limiter Recommendation and Thoughts
I use the massey in multi-mono mode. That way I can adjust the threshold on each channel.
Old 10-05-2010, 04:53 PM
SpaceCommand SpaceCommand is offline
Waves 360
Old 10-06-2010, 11:02 PM
CHD CHD is offline
I use Sonnox Dynamics, but the 5.1 compressor+limiter is TDM only.
Dmitri A. Chernov
re-recording mixer/supervising sound editor/studio owner
Moscow, Russia
http://www.imdb.com/name/nm2555539/
Old 10-07-2010, 04:40 AM
tom_lowe tom_lowe is offline
why would you want to set individual thresholds per channel? It'd play havoc with stereo imaging.
Old 10-07-2010, 08:34 AM
Postman Postman is offline
It is helpful in some cases to limit the center channel differently.
Old 07-07-2012, 11:58 PM
Brent_Sydney Brent_Sydney is offline
So given we're moving into AAX land where are people now sitting on stem limiters?
Any word on L2007 coming to AAX, anyone had contact on that?
I just dropped Colin McDowell an email, I'd love to see an AAX DSP efficient multichannel version of his ML1 limiter which is part of the ML4000, you know, support up to 7.1 and say a dozen instances per chip.
How many folks are using multi-mono versus a true multichannel limiter? The only true multis I can think of are the Digi dyn3, maxim, Smack, Impact and waves L360 and C360 and with those staying native...
It's a shame Avids channel strip compressor/limiter is so slow and cant be used as a brickwall.
Thoughts?
Old 07-08-2012, 07:25 AM
MIKEROPHONICS's Avatar
MIKEROPHONICS MIKEROPHONICS is offline
Default
Nugen are in beta with ISL ... Hold on tight as their stuff s awesome.
Cheers
cheers
Mike Aiton BSc (hons)
Audio Consultant, Dubbing Mixer/Sound Designer & Journalist
BAFTA member
IPS member
www.mikerophonics.com
Old 07-08-2012, 04:27 PM
True - but will it be AAX DSP or multichannel? Screenies and past dev suggest native and stereo.
Are you a multi-mono limiter sort of guy Mike?
Old 07-08-2012, 11:22 PM
It is multichannel and although currently in beta as RTAS, AAX native AND dsp will be rolled out. They write great software and are an ethical company too.
Cheers
cheers
BAFTA member
IPS member
HTML code is On
soft-limiter on mbox 3 soft-limiter.. overdriven tape saturation sound mjhann83 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 07-07-2011 09:01 AM
Limiter recommendation Majorek Virtual Instruments 6 02-03-2010 04:12 PM
LImiter on audiotrack Vs Limiter on auxiliar track cinetj General Discussion 2 07-15-2008 11:15 AM
Oxford Limiter vs TC brickwall limiter stargazer Pro Tools TDM Systems (Mac) 3 04-28-2006 12:32 PM
Waves L1 limiter vs. Focusrite D3 limiter??? Danny Caccavo Pro Tools TDM Systems (Mac) 1 05-01-2000 12:14 AM
