vista does not recognize my digi002 as the sound card
so i installed vista on my computer...PTLE 7.4 seems to run faster with vista.. but i have a problem, my computer recognize the 002 but not as a "sound card" so i dont have any sound coming out... what do i need to do? where can i found the drivers for vista?
when i go to the control panel it doesnt show the 002 as an option for the sound card how it used to be with xp i would really appreciatte your help thanks |
Re: vista does not recognize my digi002 as the sound card
Sorry to tell you this, but there is no wave driver for vista, so you will need another sound card in the computer to hear audio from windows and other programs.
Cheers, Justin
5198 Studios |
As far as I am aware, there is no Wavedriver (the driver that makes the 002 the default windows soundcard) for Vista. (unless something has changed recently).
And if there was, it would/should be installed with the software.
http://www.digidesign.com/index.cfm?...5&itemid=23882
Digidesign WaveDriver for Windows XP — (Not Supported With Windows Vista) The Digidesign WaveDriver is a single-client, multichannel sound driver that allows third-party audio programs that support the WaveDriver MME (Multimedia Extensions) standard to play back through the following Digidesign hardware: * Pro Tools|HD audio interfaces * 003 * 003 Rack * Digi 002 * Digi 002 Rack * Mbox 2 Pro * Mbox 2 * Mbox 2 Mini * Mbox 2 Micro * Mbox Playback of 24- and 16-bit audio are supported at sample rates up to 48 kHz, depending on your Digidesign hardware and WaveDriver client application. The Digidesign WaveDriver provides 2 channels of output on all systems. WaveDriver is not multi-client. Only one application at a time can use the WaveDriver. Be sure to disable the Windows system sounds. It is also recommended that you use a separate sound card for games or other general work. For third-party software synthesizers and samplers, or for any applications requiring full duplex input and output use the Digidesign ASIO Driver (refer to the included ASIO Driver Usage Guide). For more information, see the following document included with the installer: Windows Audio Drivers Guide
5198 Studios |
I must need more coffee...
damn that sucks!
thanks everybody for taking your time to answer... so i guess ill go back to XP. do you guys think they will have the drivers to run the digi 002 as the soundcard with vista? thanks |
The Wavedriver, in general, is in dire need of an update. When/if they develop it for Vista they should really update it.
sucks because i got vista ultimate... and runs very smooth on my computer... and the xp version i have is the home edition full crap software that makes my pc slower......
I was thinking of buying a cheap m-audio interface just to play my pt tracks through my monitor speakers.
I just connect the outputs of my cheap, built-in soundcard to the alt-src inputs of my 002R. It is, after all, what the alt-src inputs were designed for.
Mbox 2 as main sound card on vista! | 06dirty | Pro Tools M-Powered (Win) | 2 | 08-24-2010 08:41 PM |
mbox2 used as sound card on pc windows vista | arturo gatta | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 02-04-2010 08:38 AM |
Using Mbox as a sound card in Vista? | thisjanuary | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 10-06-2008 08:33 PM |
Playing audio CD through Digi002 as a sound card | SixChurchStreet | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 10-31-2007 08:22 AM |
Recommend a compatible PCI sound card for Digi002 | Jay Terrien | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 65 | 10-05-2003 12:18 PM |
