Drive Solutions for G5
I'm currently upgrading to an HD3 system and putting it in a dual core 2.3 G5. Seeing as though I'm using my pcie slots, what are people doing for drives? I have the one sata drive that is the system drive and will add a second internal sata drive for audio, but what about high track count sessions that need to span two drives? Is sata fast enough that you don't need to span the audio or? Can you span audio off an internal sata drive as well as a firewire drive? Looking for a little insight as to what others are doing. Cheers, Chris
Hackintosh 3.6 GHz 8 Core Intel Core i9 - 12.6.4 Monterey -32 gigs Ram - Carbon - Protools 2024.3 Ultimate |
Re: Drive Solutions for G5
It does depend on what frequency and bit rate you work at etc, but i use my second SATA hard drive just for audio and at 48k 24 bit i can quite easily run 80+ tracks? now this is not Digi's recommendation!! officially they recommend about 32 per drive i think! You can use external firewire 800 (and probably 400)as well, but i haven't been able to get the same track count as internal SATA. there are probably users on here who run sessions of up to 150 or above and can advise better if you're running sessions of that size!! Chris
Thanks for the info, that's the sort of real world info I was looking for.
I'm usually only at 44.1 or 48...around 80 tracks max as well. Cheers, Chris
Hi
I'm using my stock 250gig SATA for system stuff, a second 320gig SATA for audio recording, I've also added a G5 Jive rack system and a SATA Controller by Sonnet which allows me to add 3 additional SATA drives. Everything works fine!! The only issue is that you can't boot from any system drives that are mounted in the G5 Jive. Also, here's the link to check it out! http://www.sonnettech.com/product/g5_jive.html Randy G5 Dual 2.3, 4.5gb Ram, Mac OSX 10.4.9, Pro Tools 7.4 and a system with 10.4.4 with Pro Tools 7.1.cs4
Mac Pro Early 2009 3.06 Six Core 48gb ram, Pro Tools 10.3.10, HD6 Accel, Pro Tools 2021, Macbook Pro, Magma PE6R4i, Yamaha DM2000 Console, Logic 9 and 10, Apogee Big Ben, 10pcs HD 192's, Benchmark DAC-1, Distressors, API, Neve, Rupert Neve, Dangerous, Lynx, Manley ELOP+, Massive Passive, VariMu, Neumann, Peluso, A-Designs Hammer 2 & Nail, Empirical Labs, Drawmer, Lexicon U87, Bricasti M7, dbx, Cranesong, SSL 500 G-Bus, Custom Audio Germany, Dynaudio, Focal, Yamaha, TC Electronic, Mapex Drums, SPL |
I saw those, they look pretty cool. Unfortunately I don't have a free pci slot open for a controller card.
Thanks for the info though. Chris
UGH! ''DAE can't get audio from drive fast enough.'' Tried many different solutions! | Niglopte | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 01-23-2014 06:35 PM |
Hard Drive Back-up solutions | quack | Tips & Tricks | 1 | 10-07-2005 06:50 PM |
SCSI|64 drive solutions | Richard Conrad | Pro Tools TDM Systems (Mac) | 0 | 03-16-2005 06:09 PM |
PT5.1.1 need some solutions | PiratePost | Pro Tools TDM Systems (Mac) | 0 | 08-03-2001 10:18 AM |
Can't Empty Trash b/c Drive is Not online- Any Solutions? | fshrking | Pro Tools TDM Systems (Mac) | 8 | 05-08-2001 11:36 AM |
