Routing soundcard output through digi002 rack
Is there any possible way to use my digi002 rack, which is connected to my studio monitors and headphones, to hear the output of my soundcard? The reason for wanting to do this is because i use a couple of standalone softwares (ie:band in a box)which do not support RTAS. I want to hear them through my speakers and headphones without having to keep on changing my 1/4" cables back and forth between my soundcard output and my digi002 rack outputs 1 & 2 everytime i use my standalone software versus using pro tools.
Re: Routing soundcard output through digi002 rack
Run a cable from the soundcard output to the Alt Source inputs. Press the Alt Src to Mon button when you want to hear it.
dude, if this works, you're the "DIGI-MAN!" I've been asking people how to do this for ages now and nobody else seems to know. obviously, i won't have to have protools open to do this i'm assuming. also, is there anywhere on the digidesign site that explains doing this in detail? Thanks!
Ummm...no...
You run it into the alt-src , then push the ALT-SCR to mon, and then the hardware works and your sounds playboack through the device like magic. You must be using the monitor outs/out 1/2 on the digi for it to work. This has been my wavedriver workaround as well. Works like a charm! And... its pretty normal stuff for an audio engineer. Signal routing... that stuff. Cheers!
5198 Studios |
*MAGIC!* (good one, J)
There's this neat little document that comes with the 002R called "Getting Started: Digi 002 & Digi 002 Rack". This procedure is covered in there, specifically page 51: Quote:
Digi002 Rack - Output Volume Settings | accession | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 04-21-2015 05:09 PM |
digi002 soundcard not reading reason | dwayne00 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-23-2010 09:32 PM |
Still cant use Digi002 as main soundcard, 10.5.3, 7.4.2 | redhouse1985 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 05-31-2008 09:03 AM |
Using a Soundcard with Digi002 Rack Via SPDIF | digimike | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 17 | 01-30-2007 06:32 AM |
digi002 as the only soundcard on a pc?? | gylle | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 04-07-2004 01:08 AM |
