Save Session Copy
Hi All, I am experiencing a problem where Save Session Copy (with audio files) in PT 6.9.3 crashes fairly regularly. It is showing a "bad file name" error. No other crashing issues, just this one process. Any ideas on this? Thanks.......Andy Daddario
Re: Save Session Copy
Yes, I believe it is. I'll try a SSC today to verify. They are pretty big Dialogue/MX/EFX mix sessions (over 5 meg) so I don't know if that's a contributing factor or not. It does seem to be some file problem that is stopping it though.........Andy Daddario
Yeah.. if it's error -37, then this is a HUGE DOG that's been plagueing us since 5.0. Basically, PT is trying to copy the same file from 2 different locations and it's getting confused so it gives you the error. According to Digi, there IS NO FIX other than manually copying the files. So far, I have NOT seen this in 7.0 since it renames all "illeagal" files. I guess I haven't been using it long enough to run in to a duplicate.
Good Luck. |
i had this problem just recently and i was able to rename the file suspect to causing the problem and then it worked ok. it my case it appeared to be a long name or illegal charecters or something to that effect... hope this helps
Ken P. Pro Tools Ultimate, Mac Mini 3.2 i7, Mtrx Studio & Omni, 4x S1’s & Dock w/ iPad Air 2 |
Unfortunately PT doesn´t preserve the folder-structure when doing this. it tries to jam all files into one folder. On complex projects it´s nearly impossible to do a save as including files.
frank.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
Remember, you can do the "Copy and relink" function from the Project Browser. I've not had any more trouble with this one since someone here clued me in to this. I used to tear my hair out over those errors...
At this point, you probably have audio files in multiple folders, with some file(s) sharing the same name. You open the Project Browser, double click on the Audio Files folder, sort by path, and then select everything you want to copy. Then do the "Copy and Relink" function. As the operation progresses, you will see the file(s) on which the computer fails in the Task window. Then, just rename the errant file, copy it like you did the others, and you're done. Make sure you don't replace the file with the one that shares its name, as there's no guarantee that they are the same actual audio file. Unless, that is, you know for sure. Hope this helps, S.
IMDB |
Ok,I'll try all these ideas. Thanks gang..........Andy Daddario
Thanks, worked perfectly. Didn't have another "ginked" session until today. Did the relink and SSC with no problems. Thanks again..........Andy Daddario
"Save Session Copy in" occasionally doesn't copy.. | Willard | Pro Tools TDM Systems (Mac) | 0 | 03-06-2007 12:31 AM |
Can't Save Session Copy In | 1511 | Pro Tools TDM Systems (Mac) | 5 | 10-11-2006 07:27 AM |
Save Session Copy In removes files from session!!! | Jay Nierenberg | Pro Tools TDM Systems (Mac) | 24 | 11-11-2004 05:25 PM |
"Save Session Copy In" bug | KK Proffitt | Pro Tools TDM Systems (Mac) | 2 | 04-25-2004 02:12 PM |
save session copy or ?? | stickstome2 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-27-2002 11:31 PM |
